Cluster Bulb Replacement
Old Jan 9, 2008 | 10:06 PM
pin0y209's Avatar
Default 89 honda civic si
what kind of bulb goes into the cluster??? caz i cant see nothing at night..and also is there a light in the climate control caz i cant see nothing at night....
Old Jan 9, 2008 | 10:11 PM
STREETWERKZ's Avatar
Default Re: 89 honda civic si (pin0y209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of bulb goes into the cluster??? caz i cant see nothing at night..and also is there a light in the climate control caz i cant see nothing at night....</TD></TR></TABLE>
Your title should really reflect your question so it'll be easier for others to use the search function in case somebody puts the correct answer in here. You should also try the search feature yourself because I know its been covered before...
Old Jan 9, 2008 | 10:21 PM
wakaranai's Avatar
Default Re: 89 honda civic si (STREETWERKZ)
Streetwerkz--I'm surprised that HT hasn't elevated you to mod status. Or have they? Not mocking your ****, since what you are saying is legit.
Old Jan 9, 2008 | 10:23 PM
Default Re: 89 honda civic si (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">Streetwerkz--I'm surprised that HT hasn't elevated you to mod status. Or have they? Not mocking your ****, since what you are saying is legit.</TD></TR></TABLE>
we're workin' on it.
Old Jan 9, 2008 | 10:25 PM
wakaranai's Avatar
Nice.
pinoy209--Go to your local auto parts store and let them know that you are looking for bulbs for your cluster.
Old Jan 9, 2008 | 11:45 PM
24TEN's Avatar
PHANTOM MENACE
Actually it sounds like it might be your dimmer switch or dimmer switch related because both the cluster and climate control are out...
Long shot, is your dimmer switch turned all the way down? LOL
Old Jan 9, 2008 | 11:57 PM
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">Actually it sounds like it might be your dimmer switch or dimmer switch related because both the cluster and climate control are out...
Long shot, is your dimmer switch turned all the way down? LOL</TD></TR></TABLE>
Old Jan 10, 2008 | 07:19 AM
thevtecnician's Avatar
Default Re: (STREETWERKZ)
This sounds to me like a fuse. I bet your tailights don't work either you should check that out. Check all the fuses in the fusebox under your panel in the cabin. Its very rare for all the cluster bulbs to go out along with the climate control at the same time.
Old Jan 11, 2008 | 10:01 AM
pin0y209's Avatar
my fuses are okai,,tail light are okai... but do oyu guys noe wat size of bulb is it so i cud change it??? and how do chnage the climate control???
Old Jan 11, 2008 | 10:09 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: (pin0y209)
Did you verify your dimmer switch isn't turned all the way down?
And how did you check your fuses to make sure they are ok? I went to someone's house to check out why the reverse lights didn't work once and they said the fuses were fine, but when I checked I found that the problem was that there was no fuse at all.
Old Jan 11, 2008 | 10:15 AM
pin0y209's Avatar
Default Re: (24TEN)
yes my dimmer is all da way down..the fuses are okai...even my lights except foe the cluster light n climate control....so any idea on the size of the bulb and how to takeo ut the light bulb in the climate??
Old Jan 11, 2008 | 10:17 AM
CRX Toad's Avatar
Yes I get so SICK of changing titles to reflect the actual problem is makes me
Old Jan 11, 2008 | 10:19 AM
24TEN's Avatar
PHANTOM MENACE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">Did you verify your dimmer switch isn't turned all the way down?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 &raquo;</TD></TR><TR><TD CLASS="quote">yes my dimmer is all da way down...</TD></TR></TABLE>
Did you try turning it UP?
Old Jan 11, 2008 | 11:00 AM
Default Re: (24TEN)
Did you try turning it UP?</TD></TR></TABLE>
Old Jan 11, 2008 | 11:05 AM
Zaakro's Avatar
we're workin' on it. </TD></TR></TABLE>
you got my vote
Old Jan 11, 2008 | 11:38 AM
pin0y209's Avatar
Default Re: (24TEN)
yes...nothing happen..i jus need da size of the bulb and also how u take out the bulb in the climate control???
Old Jan 11, 2008 | 12:16 PM
mario_pic's Avatar
do what i did go to a scrap yeard and start pulling them out of clusters there all the same except if there the massive ones that the for some odd reasion my 91 has but as long as u can see ur oke or elts ducktape a flash light to ur cluster lmao hahaha
Old Jan 11, 2008 | 12:23 PM
24TEN's Avatar
PHANTOM MENACE
Are you sure? It's daytime right now LOL But as mario_pic stated, go to a local yard and pull them. I noticed that my Si cluster and DX non tach cluster had different sized bulbs. As far as actual size, I don't know.
PS
In the amount of time spent on this thread, you totally could've already pulled your cluster out and got the answers you seek.
Old Jan 11, 2008 | 12:31 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pin0y209 &raquo;</TD></TR><TR><TD CLASS="quote"> how u take out the bulb in the climate control???</TD></TR></TABLE>
http://www.coe.uncc.edu/~mdkeena/plate/
jadeyedragon_01
16
Mar 10, 2014 07:05 PM
sac ped
May 30, 2008 02:10 PM
sony224422
Jun 15, 2007 11:36 PM
CodyC142
15
Oct 11, 2006 11:14 AM
2manycars2choose
May 4, 2005 06:39 AM
