help with diy jumper harness
Old Jan 9, 2008 | 07:57 PM
CR-V-tech's Avatar
Default help with diy jumper harness
ok guys I'm attempting to make my own jumper harness, and i was wondering if anyone can help me out as far a figuring out all of the pin locations, i have most of them figured out but i really need help trying to figure the rest out! thanks for any input in advance!
p.s. this is for an obd2a ecu into an obd1 car (the engine is an h22a and ecu is a p5m)
Old Jan 10, 2008 | 10:45 AM
Padawan's Avatar
Darth ModerVader
Default Re: help with diy jumper harness (CR-V-tech)
http://www.phearable.net/tech/wiring/pinouts2.htm
You'll save yourself a lot of time, effort, and headaches by simply purchasing a harness. They're not very expensive, especially once you factor in the cost of the wiring, connectors, pins, solder, shrink tubing, etc.
Old Jan 10, 2008 | 04:03 PM
CR-V-tech's Avatar
Default Re: help with diy jumper harness (Padawan)
hey padawan thanks alot man
1BADEF
Sep 12, 2008 01:49 AM
pinoyboy204
Jul 13, 2006 12:14 PM
LSVTEC_ALLMOTOR
Dec 21, 2004 12:05 PM
This One
Sep 2, 2003 08:26 PM
