Are my endlinks on correctly? **PICS** and another subframe brace question.
Just put on my asr sway bar and subframe brace and just wanted to make sure the endlinks looked okay to you guys. i took the pics with m phone since it was handy:
I also found out after i mounted the subframe that they like for you to drill out the holes instead of using the factory mounting position. I just bolted the top of the subframe brace into the existing hole on the top instead of drilling the hole out. Should this be okay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">endlink spacer on the bottom is on the wrong side, which is why it looks crooked
doh. so I just need to move that spacer on to the other side then?
</TD></TR></TABLE>doh. so I just need to move that spacer on to the other side then?
Tuner Eddy
Suspension & Brakes
Jan 11, 2008 06:23 PM
emissionsux
70
Oct 28, 2007 08:32 AM
jonshonda
Suspension & Brakes
11
Feb 8, 2006 10:30 AM
Boosted Chemist
25
May 11, 2004 04:18 PM
