car wants to die when driving
Old Jan 9, 2008 | 03:49 PM
tegdude227's Avatar
Default car wants to die when driving
i have a 97 gsr just rebuilt the motor has about 2000k . at WOT it studders in higher rpm like 5 then will jump to 6. also i will just be cruising around and the car will want to die then i give it gas and it goes. then it will start to die again. does this like 5 to 8 times then it stops. put a fuel filter and fuel pump in thinking it was a fuel issues but it wasent. the car has not been tuned yet. and im not sure if all this is a tuning issue or if there is something wrong with my motor ? i also have set of shitty obx wires on it right now and if you touch them they will shock you. i was woundering if the wires were gronding themsevles out or something. any info would be awsome cuz im without a car thanx a lot
My setup
eagle rods
je pistons 10:5
acl bearings
supertech valvetrain
type r cams
stock cam gears
Old Jan 9, 2008 | 07:13 PM
frisbie21789's Avatar
Default Re: car wants to die when driving (tegdude227)
i had the same problem after i rebuilt my LS/Vtec, i changed the spark plug wires and it hasn't done it since
Old Jan 10, 2008 | 09:09 AM
tegdude227's Avatar
thanks well i got some on the way i hope thats it any other ideas or can somebody give me a good place to start ?
Old Jan 10, 2008 | 02:35 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 gsr just rebuilt the motor has about 2000k . at WOT it studders in higher rpm like 5 then will jump to 6. also i will just be cruising around and the car will want to die then i give it gas and it goes. then it will start to die again. does this like 5 to 8 times then it stops. put a fuel filter and fuel pump in thinking it was a fuel issues but it wasent. the car has not been tuned yet. and im not sure if all this is a tuning issue or if there is something wrong with my motor ?<FONT SIZE="5"> i also have set of shitty obx wires on it right now and if you touch them they will shock you.</FONT> i was woundering if the wires were gronding themsevles out or something. any info would be awsome cuz im without a car thanx a lot
My setup
eagle rods
je pistons 10:5
acl bearings
type r cams
stock cam gears
LOL..thats not normal at all..change them wires for starters..then take the car to someone thats knows how to diagnose an engine..
Old Jan 10, 2008 | 07:31 PM
M_87's Avatar
if the new wires don't take care of the problem may be the distributor.....i had a similar problem a while back (ls/vtec build), i get in my car to go to work one morning and it's bogging like hell and wanted to die as soon as i would let go of the gas, had to drive it back home (barely managed to). i thought it was a fuel related problem also, but it ended up being the distributor that was causing it to bog and die out.....
Old Jan 11, 2008 | 03:40 AM
tegdude227's Avatar
Default Re: (M_87)
so just change the cap and rotor out if the wires dont fix it ?
CimorelliCRX
Apr 7, 2022 12:16 PM
New Year Wishes
Feb 27, 2011 09:00 PM
ErrorAccord
Sep 21, 2010 04:36 PM
emooheo
Aug 9, 2007 03:35 PM
DCR
Jul 27, 2004 04:21 PM
