what year header on an h22 civic ?
Old Jan 9, 2008 | 03:48 PM
Colby71's Avatar
Default what year header on an h22 civic ?
I need to know the year of prelude header to get for an h22 eg civic.
Old Jan 10, 2008 | 04:05 AM
black'n'white's Avatar
Default Re: what year header on an h22 civic ? (Colby71)
what year is your motor? theres your answer. The header is designed for the motor, not the car. Also (i doubt this is the case, however) if your swap was originally pulled from an SH or jdm type s, make sure you get the part made for the motor the with the atts unit. they are different.
Modified by black'n'white at 7:39 AM 1/10/2008
Old Jan 10, 2008 | 10:54 AM
Colby71's Avatar
Well I was wondering becues I orderd a 95 vtec prelude header and it was way diff but I made it fit and it fits good.
Old Jan 10, 2008 | 09:25 PM
Keeper1343's Avatar
how was it different???
Old Jan 11, 2008 | 02:41 AM
Colby71's Avatar
It was alot longer and the flange was diffrent.
I deleted my cat cut the flange off from the cat that bolts to the intermediet pipe then welded that to the flange on the header. drilled some holes bloted right up.
Old Jan 11, 2008 | 06:24 AM
Keeper1343's Avatar
Default Re: (Colby71)
the header is for a prelude chassis... When the H22 is in a Civic, you have to cut the header down to the right length then weld it like you did.
Old Jan 11, 2008 | 11:00 AM
Colby71's Avatar
The one that was on it was not modified but it cracked (old) it was not modified. I think the 97+ fit. in the eg chassis.
Old Jan 11, 2008 | 03:16 PM
Keeper1343's Avatar
Not that i am aware off... It always has to be modified by bending and welding
Thepowderblue
Jun 9, 2012 02:06 AM
eg:R
May 29, 2009 01:49 AM
lude98SH
Dec 11, 2007 09:27 AM
PreIudeSI
Aug 21, 2004 06:45 PM
jdmcivicferio
Jul 3, 2004 04:05 AM
