Harness issues PLZ HLP!!!!
Old Jan 9, 2008 | 12:51 PM
typerkila's Avatar
Default Harness issues PLZ HLP!!!!
Ok heres the deal. I have a 90 4 dr ef with an a 91 Ls swap. The previous owner did the swap and the way the harness looks is just awful(the pics speak for them selves). I'm looking to put in a b16a obdo motor in replace of the Ls(not sure yet). I know I'm going to need a Si engine harness,but the harness under the dash is all messed up too. they used the original Ls fuse box. Nothing on the dash works except the cluster. I want to know if these civic have a seperate harness under the dash,would it work with the si engine harness,and if you have any parts I may need and your close to queens NY let me know. Cash in hand!!! Or to offer a hand.718-404-5119
Old Jan 9, 2008 | 12:57 PM
wiZCo's Avatar
Stouts 'n' Scotch
Good god, what a mess.
You should just get the stock harness for your vehicle's trim level, then modify it to work with the current setup. Make you life easier. And yes, there are separate dash and engine harnesses that you'll need.
Old Jan 9, 2008 | 01:09 PM
typerkila's Avatar
lol. I know its a mess I'm going to need massive help.lol But i do want the si harness just in case i do go vtec, how many harness's does this car come with engine,dash,or is that it? i know of a junkyard where i can get the original harness,is there anything else I need to make this swap look factory ?
Old Jan 9, 2008 | 01:17 PM
wiZCo's Avatar
Stouts 'n' Scotch
Get the harness that matches your trim level. All the engine harnesses are the same, except if you have an EX, get an Si engine harness. The dash harnesses may be different, as well as the cabin harnesses for sure.
Just make you life easier and get a stock replacement that matches your vehicle's year range and trim level. Then you can modify for VTEC, OBD and MPFI conversions, etc.
Old Jan 9, 2008 | 01:32 PM
mike9571's Avatar
Default Re: (wiZCo)
Whoa
yea just start all over, dont even attempt to fix that. Is it possible yes, worth it no.
you can pick up a new harness for cheap.
Old Jan 9, 2008 | 01:45 PM
alscrx's Avatar
Default Re: (mike9571)
WTF!!
Thats an electrician's nightmare . I would refuse to work on that!
Def go with new harnessesfor your model
Old Jan 9, 2008 | 01:56 PM
typerkila's Avatar
Thanks for the hlp guys. Im thinking on doing a wire tuck. What you guys think? No one has a harness for me? and make my life easier.
Old Jan 9, 2008 | 02:40 PM
Level Family's Avatar
Default Re: (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">WTF!!
X2
Just Get the original harness from a junk yard , and that would make your life easier...
Old Jan 9, 2008 | 06:07 PM
twiztid17thninja's Avatar
agreed new harness from the JY also you could post in the fs wtb thread...MY GOD i have only seen wire mess like that in a VW good luck
hondaproof
10
Mar 2, 2014 06:10 PM
thehatch97
Dec 15, 2009 09:48 PM
CiViCgT32
Jul 19, 2006 02:21 PM
93Jdmgsr
Oct 29, 2003 01:21 PM
CivicSiR7
Apr 25, 2002 06:54 AM
