eg mpfi setup on a 90 dx
Old Jan 9, 2008 | 09:22 AM
thedudefromjerz's Avatar
Default eg mpfi setup on a 90 dx
hey guys, I have a 93 eg sohc vtec intake manifold, wiring harness, resistor box, and p28 ecu. is this everything i need to convert my 90 dx to mpfi...i did searches and im confused thnx.
Old Jan 9, 2008 | 09:43 AM
black0hatch's Avatar
Default Re: eg mpfi setup on a 90 dx (thedudefromjerz)
yes but you dont need a p28 thats for a vtec motor and its obd1. if your just using your stock dx motor and making it dpfi then you need the manifold you allready have, a d16a6 dizzy, and a p06 ecu. and if you use the eg obd1 injectors you dont use the resistor box or you can get some obd0 injectors and use the resistor box. you use your stock dx engine harness and add the plugs for the fuel injectors and a different dizzy plug. you can sell the p28 and probably have enough to buy the correct parts.
Old Jan 9, 2008 | 12:28 PM
Default Re: eg mpfi setup on a 90 dx (black0hatch)
ok thanks for your help.but u said dpfi. im converting to mpfi. wouldnt i need a pm6 not a p06?
Modified by thedudefromjerz at 1:51 PM 1/9/2008
Old Jan 9, 2008 | 01:40 PM
ya i meant mpfi and pm6 you get my drift.
Old Jan 9, 2008 | 02:41 PM
chrisyaj's Avatar
From: Saint Paul, Minnesota, United States of America
hey...
so if u are just going D-series u dont need to convert to MPFI????
and just use the dx harness'sS???
Old Jan 9, 2008 | 03:07 PM
Default Re: eg mpfi setup on a 90 dx (chrisyaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisyaj &raquo;</TD></TR><TR><TD CLASS="quote">hey...
and just use the dx harness'sS???</TD></TR></TABLE>
what are youtalking about? you need to conver to mpfi if you want to. you always use the stock engine harness for your car.
douglaslovin
Mar 8, 2008 01:40 PM
CRseXy
11
Dec 30, 2004 11:29 AM
PETEDIDDY
Mar 25, 2004 08:29 AM
doublethink
Mar 17, 2004 08:58 AM
