Compression Ratios
Old Jan 9, 2008 | 08:09 AM
CRX VT-DOO's Avatar
Default Compression Ratios
I've searched and searched!
There's so many answers that i have no idea what's right.
I have an ITR block in need of a rebuild.
As far as i am aware from reading on this site PCT pistons will send the CR sky high. I'm only looking for a CR of about 12.0:1 and thought B16 P30's would be suitable.
According to C-Speedracing the CR will only yeild 11.3:1...
So, does anybody know what CR P30's would give in an ITR?
I know these kind of questions have been done to death but any help is greatly appreciated
Cheers,
Ian.
Old Jan 9, 2008 | 08:19 AM
all-mtr-teg's Avatar
Default Re: Compression Ratios (CRX VT-DOO)
This site is more accurate than the c-speedracing.
http://www.clubcivicquebec.com...f.php
Good luck w/ the build
Old Jan 9, 2008 | 01:17 PM
CRX VT-DOO's Avatar
Default Re: Compression Ratios (all-mtr-teg)
Cheers but it still seems a bit out
Old Jan 9, 2008 | 01:30 PM
00Red_SiR's Avatar
All Motor Mentor
The compression calculator has given you a fairly accurate estimatem now the rest is up to you. If you want more compression, you'll have to either use a thinner head gasket and plain the head a little or use custom pistons. The question is...why do you need 12:1 compression?
Old Jan 9, 2008 | 08:15 PM
I would shoot for 11.5-11.7:1 CR just to be a bit safer. Some flat faved valves should get you to around 11.4-11.5:1 CR, a thinner HG could get you around 11.6-11.7:1. But why is 12:1 your goal?
Old Jan 10, 2008 | 12:16 AM
CRX VT-DOO's Avatar
The reason I was aiming towards a CR of 12.1:1 is I'd like to run either Skunk2 Pro1 cams or better yet Pro2's.
I noticed on the compression calculator that the piston to deck height is slightly larger with P30 pistons over P73's, am I reading it right? If so does this mean there would be more room for valve to piston clearance as my head has been skimmed about 20tho?
Thanks again,
Ian
Old Jan 10, 2008 | 03:29 PM
00Red_SiR's Avatar
All Motor Mentor
You don't need to run that much compression to make those cams work. It would be better to have a little more displacement to get the most out of the pro 2's though. You don't have to worry about the P2V issues running those stock pistons and pro 1's unless you go crazy with your cam gear adjustments.
Old Jan 11, 2008 | 12:25 PM
CRX VT-DOO's Avatar
Default Re: Compression Ratios (00Red_SiR)
Thanks,
After a little more searching I've decided to go with Skunk2 Pro1 cams as I think the Pro2's are too big for a 1.8L. (?)
I was talking to my engine builder today and am pretty confident that I'll have a strong reliable engine, spec as follows;
B18C Block (JDM ITR)
ITR Crank
ITR Rods
ITR Girdle
P30 Pistons
Hasting Rings
ACL Race Bearings
ARP Rod Bolts
ARP Head Studs
ITR Head
Skunk2 Pro1 Cams
Crower Springs & Retainers
ITR Valves
TODA Cam Gears
2.5" Straight Through Custom Exhaust (Don't need a cat here )
S200
Not sure on a header yet, I currently have a DC Sports 4-1 Stainless but I don't think it's up to the job anymore. Does anybody know which header i could use on a 91 CRX (UK VT, same as JDM SiR) ?
Thank again
Old Jan 11, 2008 | 01:52 PM
00Red_SiR's Avatar
All Motor Mentor
That should be a good strong build for you
Old Jan 13, 2008 | 04:16 AM
CRX VT-DOO's Avatar
Cheers,
Any more opinions?
Old Jan 13, 2008 | 09:05 AM
Did you get my pm?
Old Jan 13, 2008 | 02:30 PM
CRX VT-DOO's Avatar
Sorry about that, I've replied now
grenthang
Sep 30, 2005 04:35 PM
blacksheep
Feb 21, 2005 02:37 AM
kill bill
Mar 26, 2003 11:52 AM
Spartanic
Feb 28, 2003 07:51 PM
stupidfast
Dec 16, 2002 02:40 PM
