anyone try out the new kenwwod excelon amps???
From: South LA...107th and fig to be exact...for the foo
im looking to get the x1-r...has any one here have one
heres the specs on it..im planning on running 3 12 inch kicker cvx's
Specifications
1 Ohm@14.4V Over 1000 Watts × 1
2 Ohm@14.4V 1200 Watts × 1 (100Hz, .5%THD)
4 Ohm@14.4V 600 Watts × 1 (20-200Hz, .5%THD)
Bass Boost (Wired Remote) Hz, Hz, +dB
Infrasonic Filter 15,60,15,60,15,60,15,60Hz-15,60,15,60,15,60,15,60Hz (Selectable), -24dB/oct
Low-Pass Filter 40-200Hz (Variable), -24dB/oct
Maximum Output Power Watts
RMS Power Output 600 Watts × 1 (1%THD+N) (4Ω)
Signal-to-Noise Ratio dB
Variable Band Reject Filter 40Hz-200Hz, Off/-6dB/-12dB
Specifications
from me.
