MY LS VTEC BUILD (8D)
Old Jan 8, 2008 | 08:40 PM
EF_ST@TUS's Avatar
Default MY LS VTEC BUILD (8D)
OK, so I have been in the game for a quick minute and I have not only always wanted to do a "build thread", but a motor build period.
This is my first build and I would glady accept suggestions/comments from those who are experienced, I have the "how to build a "reliable" LS VTEC/B20" thread printed and binded..
I came up on a B18B1 from my buddy mannyman2 Thankx bro!!
Since I work at a machine shop that makes pistons, I was stoked. So on to the build..
Day one at the shop
The block got rained on... Only good for a rebuild. I brought the motor home in the trunk of my girlfriends Toyota Yaris!
The motor was pretty clean inside, the cams had rust forming on the lobes where they were touching the lifters....
Day 2 tear down of the block
day 4 block is bare
Now sending the block to get hot tanked, bored and honed.
Old Jan 9, 2008 | 05:30 AM
EF_ST@TUS's Avatar
54 views and not even a "good luck"
peeping tom's
Old Jan 9, 2008 | 05:32 AM
EF_ST@TUS's Avatar
I know they are shitty pictures, I'm trying something new today...
Old Jan 9, 2008 | 05:36 AM
queda's Avatar
im doin a ls vtec myself. best of luck to u
Old Jan 9, 2008 | 05:53 AM
D-Rob's Avatar
Default Re: (queda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_ST@TUS &raquo;</TD></TR><TR><TD CLASS="quote">54 views and not even a "good luck"</TD></TR></TABLE>
Good luck.
- Derek
Old Jan 9, 2008 | 06:06 AM
racebucket_eg's Avatar
Default Re: (D-Rob)
Here is a link that I found helpful on engine assembly, although, you work at a machine shop so I am sure there are knowledgeable people around you. http://forums.evans-tuning.com...build
What are your plans for the motor? You going to run aftermarket rods/pistons or stick to stock rods/cast pistons? Have you made your choice on bearings that you are going to run (oem, acl, clevite, etc.).
Old Jan 9, 2008 | 06:45 AM
Turbo EG4's Avatar
From: Ghost riding my grandmamas whip YEP, Los Angeles Cali
Default Re: (EF_ST@TUS)
Old Jan 9, 2008 | 04:28 PM
EF_ST@TUS's Avatar
Default Re: (racebucket_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racebucket_eg &raquo;</TD></TR><TR><TD CLASS="quote">Here is a link that I found helpful on engine assembly, although, you work at a machine shop so I am sure there are knowledgeable people around you. http://forums.evans-tuning.com...build
Glad you asked, going to run:
-B16a head (port/polish, new V/T, ITR manifold, port T/B etc..)
-custom probe forged aluminum pistons (waiting for the block to get done before I make them)
-Probe Ultralite rods
-Clevite bearings
-ARP head studs, rod bolts
Still learning a lot every day about the build. I left out a lot obviously, still changing and generating the shopping list.
Old Jan 9, 2008 | 05:28 PM
ekBlackHatch's Avatar
i apologize for no one chiming in and putting some advice or even a " " but grats on the build buddy im in the process on mine also and i know the feeling would be nice to see atleast a GL. Anyways what cams/valvetran u plan on running!?!
Old Jan 9, 2008 | 05:53 PM
-Clevite bearings
Awesome choice of parts, Probe gets a . Glad not to see another eagle h beam rod for a N/A build.
What cams are you leaning towards?
Old Jan 9, 2008 | 06:21 PM
EF_ST@TUS's Avatar
Default Re: (ekBlackHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekBlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">i apologize for no one chiming in and putting some advice or even a " " but grats on the build buddy im in the process on mine also and i know the feeling would be nice to see atleast a GL. Anyways what cams/valvetran u plan on running!?!</TD></TR></TABLE>
Havent decided on the cams there are alot of company's that seem to be pretty reputable, but I also have a lot of people at my work that have friends that manufacture all of the things I need, I am still sourcing
Valvetrain is also a undecided I'm in the process of reading the 1,000,000,000 + posts on the topic.
You have heard of Probe? I work there
http://www.probeindustries.com
The new 2008 catalog came out, its not on the site yet tho... PM me your mailing address and I'll send one
Old Jan 9, 2008 | 06:45 PM
-Darren-'s Avatar
looks like a nice start. make sure you do it right the first time, and keep us updated.
good luck, take your time, and have fun.
Old Jan 9, 2008 | 08:14 PM
Yeah I have heard of probe, must be a pretty cool job.
Got a question though, since you work at probe figured you would be good to ask. Do the probe rods come from the factory with arp rod bolts, or are you buying them separately to use?
Old Jan 9, 2008 | 09:22 PM
EF_ST@TUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racebucket_eg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I have heard of probe, must be a pretty cool job.
Got a question though, since you work at probe figured you would be good to ask. Do the probe rods come from the factory with arp rod bolts, or are you buying them separately to use?</TD></TR></TABLE>
They come with them
Old Jan 10, 2008 | 01:37 AM
gsrob's Avatar
Nice start to the build man. Keep up the pictures, I will definately be watchin the motor goin together if you keep everyone updated. When are you aiming to have the motor put together? Also, what car is it going into and what will it be used for? It looks like you work at the perfect place to take on a project like this. Good luck man
Old Jan 10, 2008 | 05:26 AM
EF_ST@TUS's Avatar
Default Re: (gsrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrob &raquo;</TD></TR><TR><TD CLASS="quote">Nice start to the build man. Keep up the pictures, I will definately be watchin the motor goin together if you keep everyone updated. When are you aiming to have the motor put together? Also, what car is it going into and what will it be used for? It looks like you work at the perfect place to take on a project like this. Good luck man </TD></TR></TABLE>
Thanks!! I will keep every one updated as best as I can. Not sure exactly when it'll be done, there is much to be done.
The motor is going in my 91 Civic SiR project. Used for road racing/ street/ occasional drag
Probe is a cool company, the owners are all interested cuz I'm the only one that's building a Honda.
BoboyRS
Aug 30, 2009 10:41 PM
bweezy615
Jun 20, 2008 01:29 AM
sixtodc4
Jan 6, 2008 10:26 AM
99hondacura
Jun 24, 2006 10:39 AM
BrainzIRL
Mar 22, 2006 05:52 PM
