Trouble shifting into first
Old Jun 30, 2002 | 12:42 AM
crxcess's Avatar
Default Trouble shifting into first
Under normal driving conditions, I sometimes can't get the car into first gear at a stop light. It is a 96 gs-r, that hasn't been abused(girlfriend won't let me tear it up).
Is there some kind of adjustment I can make? I did put a short shifter in it. It was one of those skinny ones where I had to add washers where it attached to the shift linkage to take up the extra space. It is as close to stock position as I could get it though. I didn't think it would make much of a difference.
A bad synchro into 1st? is that possible? has it happened to anyone?
Old Jun 30, 2002 | 12:46 AM
B-Series Sol's Avatar
Default Re: Trouble shifting into first (crxcess)
it is possible to have a bad first gear syncro, but no one notices it because how often do you downshift into first? this doesnt sound like a syncro problem either, bad syncro's grind...
If you just can't get into first, I would start by putting the stock shifter back in to see if that makes a difference. (just to isolate the problem)
From my experience, those cheap short shifters only screw things up. A skunk2 shifter might be more suitable. If you dont want to spend hte money, just work on shifting faster, and dont wine about it.
-Jake
Old Jun 30, 2002 | 06:46 AM
ebelp's Avatar
Default Re: Trouble shifting into first (B-Series Sol)
For most people, shifting into 2nd gear, and then going straight up to 1st usually helps it slip right in....
Old Jun 30, 2002 | 06:52 AM
ragejed's Avatar
Default Re: Trouble shifting into first (ebelp)
let of the clutch, and press it back in again, then shift to first
Old Jun 30, 2002 | 07:46 AM
Rory Breaker's Avatar
I agree with both of the above. Also try and blip the gas and it should pop in.
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
95turbodteg
Honda Civic (2006 - 2015)
Jan 14, 2007 07:56 PM
DI9ITAL
Feb 8, 2003 09:09 PM
threatcon13
Aug 7, 2001 04:20 PM
Acura97GSR
Jun 29, 2001 07:39 AM
