Passenger side water leak
Hey people of ht, i need your help with my 1995 integra ls. The passenger side floor gets soaked after it rains outside. I looked around and have no idea where the water is coming from. Any tips or info where i can take my car to get it fixed?
-thanks-
-thanks-
http://g2ic.com/forums/showthread.php?t=163003
im not sure if its the same problem that a lot of DA's have but heres a link to fix it. it probably shouldnt be too different from a DA.
any mechanic...
i had the same problem in my 93 DA... its leaking from panel located below your windshield (on passenger side)... there are a couple of holes there when you lift up the panel that are coverd by plastic clips/washers that are probably old and dont keep out the water any more... and instead of routing the water down the exit lines its leaking directly into your heat blower... thats what happened with me
This happened to me. After using a whole tube of sealant, sealing every gap I could find it still leaked. Problem - The useless windscreen repair company hadnt put my windscreen in properly!!! So if you've just had that changed then theres a possibilty. Also the windshield frame tends to rust some times and therefore create gaps for water to get in.
im experiencing tha same problem in my 00 teg right now. i found out it was tha weather strip around tha door that was leaking. it was just on tha bottom in front of tha passenger seat so i put a towel in tha door there and its dryer. but im gona get tha weather strip replaced soon. rain
Project T
Apr 27, 2009 04:48 AM
