Which IACV for this manifold/setup..
Ok... To start off.. This build is a LSVtec swap, going into a 1993 OBD1 Integra.
I believe the intake manifold I have is a Gen2 B16 (three raised bars on top of the manifold, VS the PGMFI lable), but my question is, which IACV should I use? Upon searching the web a bit, I found the comparison picture posted on FFSquad
And, upon looking at my B16 manifold (and a B18B manifold), it looks as though the B16 can use both of the different IACV types?
Bottom is the B16, top is a B18B.
So, bottom line, my question is: Is there a difference between a VTEC IACV and non-VTEC IACV? And, which should I be using for my setup? ('93 obd1 Integra, using a chipped P28 ecu)
blackeg
Dec 9, 2010 06:22 AM
b16, b18b, civic, comparison, difference, differences, ecu, iacv, intake, lines, manifold, s2k, set, types, vtec
