Check these axles, which one should I get?
Old Jan 8, 2008 | 03:02 PM
Terabass's Avatar
Default Check these axles, which one should I get?
2001 Honda Accord
4cyl, 120,000 miles, manual, EX
My car vibrates during acceleration, no other time but during acceleration, I believe it is the CV joints that are broken.
Anyway, if I am correct on that note I wish to get some new axles/CV joints..
I am looking at these axles, but I am a little confused which ones to get and why are there so many different. I assume I need the ones for $55 on the top.. but what are the rest for, the website has a fairly tough return-policy so I want to make sure to get the right ones first time out.
http://cpwstore.carpartswholes...+9273
What you guys think?
Oto
Old Jan 8, 2008 | 05:34 PM
steerh67's Avatar
Default Re: Check these axles, which one should I get? (Terabass)
the site seems to be pretty clear to me. You need the passenger side, and since you have an EX you most likely have abs. Other than that, the only other thing that matters is if you have an automatic or manual transmission.
Old Jan 10, 2008 | 01:49 PM
Terabass's Avatar
Default Re: Check these axles, which one should I get? (steerh67)
I don' t question your credibility, but what makes you say that I need the passenger side?
Is that the only side that would cause vibration during acceleration?
Let me know...
Old Jan 10, 2008 | 02:08 PM
steerh67's Avatar
when you said you thought you needed the top one i assumed you already knew you needed a passenger side axle. The only way to know which one you need is to get under the car and visually inspect the axle, look for ripped boots and such. The vibration during acceleration could be caused by a variety of things. Where do you feel it, the seat, pedal, or steering wheel?
404_FSP
Dec 14, 2017 08:04 AM
RustyStew32
Transmission & Drivetrain
Sep 21, 2015 12:03 AM
brownie75
May 27, 2015 02:00 PM
Sorcerer
Sep 29, 2010 03:41 PM
Rain_man
Aug 10, 2001 10:35 AM
