ECU Code Help!!!!!
Old Jan 8, 2008 | 02:26 PM
kwizical's Avatar
Default ECU Code 15,16 Help!!!!!
I'm Getting ECU error codes 15,16 Here are my symptoms, Irradic Idle (fixed with new distributor/rotor and wires) when stopping and letting off the gas car stalls out. Please some one HELP me!!!!!
Old Jan 8, 2008 | 03:45 PM
GSX 4G63T's Avatar
Vacuum leak. And https://honda-tech.com/zerothread?id=682412
Old Jan 8, 2008 | 10:10 PM
kwizical's Avatar
Default Re: (4163175587)
I checked for that. nothing.. I found out that the distributor cap was faulty. so i replaced it. new o2 sensor still same problems now I'm getting and Error code 8 TDC sensor?
Old Jan 9, 2008 | 09:05 PM
twiztid17thninja's Avatar
the code 16 is fuel injectors my car had that prepetually with dpfi ran fine but every now and then it wouldn't start it is late and i am too lazy to look up what the other codes are sorry
Old Jan 10, 2008 | 08:53 AM
kwizical's Avatar
Default Re: (twiztid17thninja)
when i changed out the o2 sensor error 16 went away. now I'm getting error codes 4 8 and 15 all on the distributor. what should I check I replace the ignition module still same problem..
Old Jan 11, 2008 | 09:55 AM
kwizical's Avatar
Default Re: (kwizical)
after I unhooked the battery all error codes went away. now the fuel pump isnt' working any advice would a fuel pump give me all thoes symptoms?
xtegx
Mar 19, 2010 12:39 PM
kwizical
12
Mar 10, 2008 08:05 AM
allm0torGSR
Apr 23, 2004 04:00 PM
sas92326
Feb 3, 2003 06:57 PM
JunkeeCrx
Sep 13, 2001 03:42 PM
