93 Wiring Harness
Old Jan 8, 2008 | 01:04 PM
00CivicGirl's Avatar
Default 93 Wiring Harness
We have to replace our engine wiring harness and its a 93 LS. Will a 94-95 ls wiring harness work on this?
The harness is burnt and needs to be replaced and we have an extra wiring harness for a 94-95, just trying to see if this will work or if we need to track down a 93 ls harness
Note: the car is a 93 ls with a jdm b18b motor (pretty much the same as a b18b1)
Old Jan 8, 2008 | 02:49 PM
thewrai6th's Avatar
Default Re: 93 Wiring Harness (00CivicGirl)
I doubt it, the ECUs are completely different between those years.
Old Jan 8, 2008 | 02:51 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 93 Wiring Harness (thewrai6th)
BUT 92-95 are all obd1....
Old Jan 8, 2008 | 02:54 PM
thewrai6th's Avatar
Default Re: 93 Wiring Harness (GRAF-FITI)
Maybe then, as long as all the sensors are also in the same locations.
Old Jan 8, 2008 | 03:17 PM
yes both the harness and the car are obd1..thats why i thought they would work
Old Jan 8, 2008 | 03:19 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">yes both the harness and the car are obd1..thats why i thought they would work</TD></TR></TABLE>
Well then why not
You'd probably have a problem with the dizzy/alt/injectors if it wouldn't work.
Old Jan 8, 2008 | 03:20 PM
thewrai6th's Avatar
Are the blocks the same? all sensors in the same place, etc?
Old Jan 8, 2008 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">Are the blocks the same? all sensors in the same place, etc?
the motor in the car is a jdm b18b..the harness is for a b18b1..i think the motors are basically the same
Old Jan 8, 2008 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">I doubt it, the ECUs are completely different between those years.</TD></TR></TABLE>
they are the same ecu..pr4 in the car and 92-95 obd1 are pr4
Old Jan 8, 2008 | 03:48 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
I honestly don't see why it wouldn't work, same OBD and practically the same engine...
Old Jan 8, 2008 | 03:54 PM
thewrai6th's Avatar
Then yeah, try it out. For some reason i was thinking the 93 was OBD0. If the blocks and sensors are the same, it should work.
Old Jan 9, 2008 | 08:58 AM
It worked!
tcrintegra
Oct 27, 2007 07:01 AM
93baggedcivic
Jul 9, 2007 06:00 PM
accordheat
Jun 6, 2007 10:21 PM
fwdlooser93eg
Aug 14, 2006 01:59 PM
