!Help did compression test now car wont start!!
Old Jan 8, 2008 | 12:59 PM
steveo135's Avatar
Default !Help did compression test now car wont start!!
So I got a 97 GSR which i just did a compression test on... pulled all wires, plugs... tested each cylinder at WOT put all plugs in correct cylinder with proper plug wires... go to start the car and it cranks but wont start...
Any ideas??
I did not disable the fuel pump while doing this... could that have been a problem? any ideas to help get it started??
thanks in advance...
Old Jan 8, 2008 | 01:05 PM
chocolatesk8er10's Avatar
Default Re: !Help did compression test now car wont start!! (steveo135)
did you unplug your distributor or take out the fuse? if not your probably fried the ignition coil
Old Jan 8, 2008 | 01:09 PM
steveo135's Avatar
Default Re: !Help did compression test now car wont start!! (chocolatesk8er10)
oh **** dude thats exactly what i did
i tried checkin for spark but got nothing... i held the thread of the plug against the ground wire on the block and got nothing... any idea how to fix that?
Old Jan 8, 2008 | 01:11 PM
steveo135's Avatar
how would i go about unplugging the dizzy? theres only 4 wires and they all go to the plugs... unless i didnt check too well...
Old Jan 8, 2008 | 03:57 PM
well your going to have to get a new ignition coil to get your car running but in the future the plug that is supposed to be unplugged when doing the test is right behind(when looking straight into the engine bay) the distributor.
Old Jan 8, 2008 | 04:10 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chocolatesk8er10 &raquo;</TD></TR><TR><TD CLASS="quote">did you unplug your distributor or take out the fuse? if not your probably fried the ignition coil</TD></TR></TABLE>
x2
Old Jan 8, 2008 | 04:18 PM
ovadik's Avatar
IGNITION COIL IF NO SPARK
Old Jan 8, 2008 | 04:30 PM
all-mtr-teg's Avatar
doesn't removing the ecu and backup fuse take care of the fuel and ignition?
Old Jan 8, 2008 | 06:13 PM
steveo135's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chocolatesk8er10 &raquo;</TD></TR><TR><TD CLASS="quote">well your going to have to get a new ignition coil to get your car running but in the future the plug that is supposed to be unplugged when doing the test is right behind(when looking straight into the engine bay) the distributor.
yeah dude i found the plug when removing the dizzy to replace the ignition coil got it all done after running all over the state to find one... thanks for all the help guys
i learned my lesson about compression tests... $70 later
Old Jan 8, 2008 | 06:55 PM
live and learn man, how do you think i knew so much about it
anht
13
May 1, 2010 11:57 AM
rs_racer_20
Jul 8, 2009 05:59 PM
Bngo731
Jun 5, 2006 02:42 PM
tpr
Sep 13, 2005 09:00 AM
xhimurakenshinx
Apr 2, 2005 06:36 PM
