Lower control arm bushings
Old Jan 8, 2008 | 08:19 AM
androide016's Avatar
Default Lower control arm bushings
How do I replace the front lower control arm bushings? any special tool required?
Old Jan 8, 2008 | 09:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Lower control arm bushings (androide016)
-basic hand tools with metric sockets and metric wrenches
-tool to pop lower ball joint out of lower control arm (a hammer hit against side of LCA usually works as well)
-something to support knuckle/brakes while LCA is out
-a hydraulic press with the right size adapters to push the old bushing out and the new one in
Old Jan 8, 2008 | 10:26 AM
Default Re: Lower control arm bushings (TouringAccord)
Well thanks, I'll need a shop cuz i dont have a press.
Old Jan 8, 2008 | 10:55 AM
H-T Order of Merit
if you can, remove the control arm and take it to a machine shop and just have that work done and do the rest yourself. That'll save you some money as long as you have a way to get around while the car it down.
Old Jan 8, 2008 | 11:10 AM
yes that is what im thinking, i did the same when i replaced the lower ball joints.
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
94vtirozguy
Apr 14, 2006 11:37 PM
94vtirozguy
Suspension & Brakes
Apr 3, 2006 08:32 PM
PaulB
May 3, 2004 05:36 AM
illusion
Sep 10, 2002 05:13 PM
