Brake replacement write up?
Anyone know where I can find a free online Repair Manual for a 2nd Gen. CRX Si?
I'm looking for a brake replacement step by step write-up but all I can find are brake conversions.
If there is no info, Can anyone that has done this give me a real basic write up?
I've done it on different cars but there are a few things that change in each car.
Thanks in Advance.
Thanks in Advance.
dude like they say "if you don't know how to do it get someone that does."
but pretty much what you need to do is for the fronts unbolt the top bolt and swing the caliber down push in piston and put pads in. on the back its kind of the same thing but you have to twist the piston in and make sure the rubber seal doesn't twist. lube up the seal with vaseline to keep it fresh
NewRacer
Jul 20, 2003 02:35 PM
