DC vs JDM ITR
I was in a brief conversation about this and no one has been able to give me good reasons or explanations. I was told that for the potential of my b16 build the it would be better to go with a original ITR header vs the DC sports 4-into-1. Can any one help convince me this is true. only reason I can gather is clearence issues, I know many people have problems with this.
that was my thought as well and being that they are thinner walls and ceramic coating I would think that would actually increase potential performance by releiving a few degrees off your EGTs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondachrisEJ1 »</TD></TR><TR><TD CLASS="quote">that was my thought as well and being that they are thinner walls and ceramic coating I would think that would actually increase potential performance by releiving a few degrees off your EGTs</TD></TR></TABLE>
which would also make it more likely to crack as well....i ran a DC ceramic coated header long ago on my dual cam zc and definantly will never run one again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots »</TD></TR><TR><TD CLASS="quote">
which would also make it more likely to crack as well....i ran a DC ceramic coated header long ago on my dual cam zc and definantly will never run one again</TD></TR></TABLE>
I've never had a problem with the DC headers I have owned. Did you wrap yours? That tends to hold in the moisture and leads to cracking over time from what I have seen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote"> just one made out of ceramic..</TD></TR></TABLE>
I don't belive it's made out of ceramic, just coated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">
The DC has larger primaries, a better collector, and no inner welds on the flange. It is quite similar in design to the Mugen 4-1. It will flow better and perform better than the JDM ITR 4-1, though not necessarily by a significant degree. Ground clearance on either header will not be terribly good if that's a main concern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">
I've never had a problem with the DC headers I have owned. Did you wrap yours? That tends to hold in the moisture and leads to cracking over time from what I have seen. </TD></TR></TABLE>
it was unwrapped...it was the shitty 2 piece design
JDM_EK4_Coupe
Apr 17, 2007 04:52 AM
urtz
18
Apr 14, 2007 09:48 AM
tianporn
Jul 27, 2005 04:44 PM
