Lighting HID/Xenon kits, Retrofits and Associated Topics
In the process ofmy first retro... I have some ?'s
Old Jan 7, 2008 | 07:58 PM
-[95cxhatch]-'s Avatar
Default In the process ofmy first retro... I have some ?'s
I am in the process of my first retrofit project and have a few questions. I have trimmed the housings and mounted the projector so that I can still retain the factory adjusting screws. So far my only problem is I have had to trim in areas that are not covered by my shrouds.
Here is what I have started with:
Here is where I am at right now:
My only concerns at this point are
- What can I use to fill in the areas around the shrouds?
- What is the best adhesive to use to bond the front glass to the plastic?
Any comments or suggestions are welcome.
-Chad
Old Jan 10, 2008 | 07:43 PM
Default Re: In the process ofmy first retro... I have some ?'s (-[95cxhatch]-)
bump for some replies....
Old Jan 11, 2008 | 05:28 AM
Genuine Rolla's Avatar
For bonding the lens to the body of the headlamp, you could pick up some LiquidNails Sealant at your local wal-mart. To cover up those holes in the back, what you could do, is paint the reflector and anything else that you wish, black. That should hide it well so that its not easily noticable.
Old Feb 19, 2008 | 11:13 PM
v.i.massive's Avatar
jb weld thats what the euro guys use
Old Feb 22, 2008 | 12:55 PM
striker_18's Avatar
Default Re: In the process ofmy first retro... I have some ?'s (v.i.massive)
lense is sitting too far back and will cause glare problems once they are fired up. That is due to some foreground light will hit the bottom side of your reflector and that will reflect the light upwards. Get a smaller projector such as the fx35 or g35 projectors. They fit well but you gotta do alot more work.
Old Feb 22, 2008 | 07:10 PM
6SPD_EK's Avatar
Default Re: In the process ofmy first retro... I have some ?'s (striker_18)
buy OEM nissan tailight sealant to seal the housing lenses
ClutchVtech9
Paint and Body
Jul 21, 2009 05:07 PM
preludesi93-arg
Oct 3, 2005 02:29 PM
fatlips
Honda S2000
Mar 18, 2004 04:21 PM
Yogi bear
Jul 3, 2003 11:20 PM
