Best Throttle Body?
Old Jun 29, 2002 | 09:24 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Best Throttle Body?
Pretty self-explanatory thread I guess.
My friend has a fully-built B18C with all of the goodies like JUN 3s, 12.5:1 CR, done-up head, blah, blah... but he's missing one key component:
Throttle Body
What I'm interested in is info on various TBs including your opinions based on experience with the various ones avaialble. Performance, price, etc.
I called Erick's Racing and they no longer offer a 70mm TB - in fact, they cannot offer TBs because of a conflict of interest with a sponsor.
I know of SPOON, nut it *seems* pricey unless it is hand-down the best out there.
Thnaks in advance for any suggestions.
Old Jun 29, 2002 | 09:28 PM
TaboR's Avatar
New User
Default Re: Best Throttle Body? (B18C5-EH2)
i will just get the stock one and bore it
Old Jun 29, 2002 | 09:41 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Best Throttle Body? (FreddyR)
What about BBK? Good product?
I'm uaually afraid of "Mustang" parts or whatever, but I've been seeing good things from users here on H-T.
Anyone else?
...And no it's not for me. I could give 2 ***** about buying a TB - mine is just fine and will never be swapped or altered probably.
Old Jun 29, 2002 | 09:58 PM
GokuSSJ4's Avatar
the things with BBK that some use to get stock (especially if you were in traffic for a long period)
with Ericks hmm! im going to ask him .....why ? but
Ericks TB is one of the best out there , not just for performance but also money wise .....
Old Jun 29, 2002 | 10:00 PM
GokuSSJ4's Avatar
Default Re: Best Throttle Body? (Spoon1)
Old Jun 29, 2002 | 10:20 PM
K1R's Avatar
K1R
the B18c5 I/M is smalll than 68mm.
you need to match port the I/M and new gasket
to get full power of BBK or Erick T/B.
Old Jun 29, 2002 | 11:00 PM
Spikey's Avatar
check this one out... we're working on a 80mm-66mm TB
Old Jun 29, 2002 | 11:05 PM
Kengs's Avatar
Default Re: Best Throttle Body? (Spikey)
That looks nice
Old Jun 29, 2002 | 11:20 PM
Spikey's Avatar
Default Re: Best Throttle Body? (kengs)
thanks
btw, with regards to the Spoon, it is 70mm OD taper bored to the stock ID.
it is quite pricey, but you are getting a new core, so the cost include the price of a new OE Honda TB which isn't cheap to begin with... and then Spoon markup......
Old Jun 30, 2002 | 12:14 AM
AJ PwR's Avatar
80-66mm... we need the velocity (ventuli effect ) for the RESPONSE.
Old Jun 30, 2002 | 12:17 AM
Kengs's Avatar
Default Re: Best Throttle Body? (AJ PwR)
What intake Ben? ARC?
Old Jun 30, 2002 | 12:22 AM
AJ PwR's Avatar
I will post pics next week.
Old Jun 30, 2002 | 01:09 AM
mafay2's Avatar
New User
Since your friend have the full JUN set up, why not go with the JUN IM and its 90mm TB?
Old Jun 30, 2002 | 01:38 AM
spoonek4's Avatar
Probably not Kengs.
I'm waiting for more info on that TB too.
Old Jun 30, 2002 | 02:54 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Best Throttle Body? (spoonek4)
I appreciate all the replies.
I don't think a JUN manifold or TB or individual TBs in even an option. He's already sank a lot of loot into the motor, so the TB needs to be something a tad more budget-conscious.
And again I already spoke to Erick (from Erick's Racing) and again the 70mm TB is no longer available. All they had at the time were a few 68mm and those may have been the H and F-series ones.
So any more feedback on the BBK?
AJR - how much longer before you guys are done with yours, and how much U.S will it cost?
Thanks in advance!
Old Jun 30, 2002 | 03:02 AM
Kengs's Avatar
Probably not Kengs.
Then what J? RS Horie?
Old Jun 30, 2002 | 03:36 AM
RICHJ's Avatar
Oops, more than one TB here.
http://www.jenvey.co.uk/
[Modified by HardHead42, 1:29 PM 6/30/2002]
Old Jun 30, 2002 | 05:59 AM
743power's Avatar
Default Re: Best Throttle Body? (HardHead42)
The spoon TB may be $500, but it comes with a brand new tps and map sensor, both of which cost $250 at the dealer. Inline four offers overboring services now, so check out http://www.inlinefour.com</a>. Jdmhondaparts also sells big bore TB's, which look like htey might be made by ericks. <A HREF="http://www.jdmhondaparts.com" TARGET="_blank">http://www.jdmhondaparts.com.
This is the one from jdmhondaparts. It's $390, and available in 66 or 68mm straight through design.
[Modified by 743teg, 7:36 AM 6/30/2002]
Old Jun 30, 2002 | 07:36 PM
GQ 05YellowEVO8's Avatar
I may be interested in those
Old Jun 30, 2002 | 07:40 PM
DCtwoR's Avatar
Default Re: Best Throttle Body? (VTEC-MAN95GSR)
spooooon
too pricey...only reason i got one was cuz my tps went out
Old Jun 30, 2002 | 07:48 PM
geometro's Avatar
JG/Edelbrock does have an oversized throttle body (65mm). OEM'd by Magnetti Marelli... It may be vapor ware as I have yet to see one in real life.
Also, King Motorsports offers a overboring service...I think they run about $175 or something like that for a 4mm overbore.
Just out of curiosity, on the topic of JG/Edelbrock parts, has anybody seen any performance gains with their VictorX intake manifold (either by itself or in conjunction with their throttle body) in a NA application? THe only dynoplot I've seen is from a boosted (20psi) application...
-Geo
Old Jun 30, 2002 | 07:51 PM
Bob#455's Avatar
Default Re: Best Throttle Body? (geometro)
From King's website:
"The KMS Big Bore Throttle Body is the perfect addition for those who want more intake capacity when using big camshafts, radical headwork and more compression. We enlarge your throttle body by 4mm. A new throttle plate is installed and the throttle body bore is tapered, enlarged and polished to fit. Each throttle body is bead blasted for perfect appearance and the TPS sensor is reset for optimum performance."
[Modified by Bob#455, 8:51 PM 6/30/2002]
Old Jun 30, 2002 | 10:07 PM
Big Phat R's Avatar
Default Re: Best Throttle Body? (Bob#455)
A&J Racing does the exact same thing for cheaper.
Old Jun 30, 2002 | 10:21 PM
Mike M's Avatar
Founding Member
I Spoke to Scott on that, For the ITR its actually bored to 64-65mm. I'm sending them my core next week.
Old Jun 30, 2002 | 11:15 PM
EGtoR's Avatar
Spoon TB is totally waste of money if you already have ITR TB.
Just send it out to a good machine shop near where you live and have them bore it out and taper it. I don't think you want too much downtime by sending it too far away, and you definitely don't want to send it to Canada if you are in the US. The custom is so bitchy lately, GOD know how long you will have to wait.
