want to confirm before i start hacking away!!!
Old Jan 7, 2008 | 07:19 PM
2ltrtodd's Avatar
* B A N N E D *
Default want to confirm before i start hacking away!!!
k i did a d16 swap in my winter civic. im trying to wire in the extra injectors.
on the a,b,c plugs the diagram i have and plugs are different....
are they numbered like this :
1 2 3 4 5 6 7 8 9 10
11 12 13 14 15 16 17 18 19 20
or
19 17 15 13 11 9 7 5 3 1
20 18 16 14 12 10 8 6 4 2
and 1 more thign if i used the stock d15 dizzy do i skip those steps for crank angle and stuff??
thanks.
Old Jan 7, 2008 | 07:30 PM
black0hatch's Avatar
Default Re: want to confirm before i start hacking away!!! (2ltrtodd)
i dont really understand what you saying but you cant use the dx dizzy youll get a cel and wont be able to rev past 3k.
Old Jan 7, 2008 | 08:05 PM
2ltrtodd's Avatar
* B A N N E D *
Default Re: want to confirm before i start hacking away!!! (black0hatch)
ok well someone told me i could thats why... ill put the other one back on.
and what i mean is on the clip itself its labeled as
1-10 on the top and 11-20 on the bottom
and the diagram i have for the plugs is
20 18 16 14 12 10 8 6 4 2 on bottom and
19 17 15 13 11 9 7 5 3 1 on the top
so which one is the correct way thats the ecu plugs are numbered?
Old Jan 8, 2008 | 02:57 PM
2ltrtodd's Avatar
* B A N N E D *
o ya and why cant i use my d15 dizzy??? im using the stock computer not the one for the d16.
Old Jan 8, 2008 | 04:24 PM
jedb18's Avatar
I'm assuming you are trying to use a PM5 ecu and that wont work with mpfi
Old Jan 8, 2008 | 05:58 PM
Default Re: want to confirm before i start hacking away!!! (jedb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ltrtodd &raquo;</TD></TR><TR><TD CLASS="quote">o ya and why cant i use my d15 dizzy??? im using the stock computer not the one for the d16.</TD></TR></TABLE>
then your car is not going to run. just put your old dpfi manifold on the d16 then it will run with your stock dizzy and ecu. dont start hacking away unless you got all the right parts for it.
Old Jan 8, 2008 | 06:08 PM
2ltrtodd's Avatar
* B A N N E D *
im using a pm9 ecu not a pm5. and ive already started doing this im almost finished. except for the dizzy which im still wondering about..
i cant use the dizzy thats from the motor because its got a different plug at the since one is 1990 and one is 1997.
Old Jan 8, 2008 | 09:31 PM
Jonknee's Avatar
wait why are u using a 97 dizzy
Old Jan 8, 2008 | 11:13 PM
89s1's Avatar
Default Re: want to confirm before i start hacking away!!! (Jonknee)
he isnt using a 97 dizzy, hes using a 97 d16 and cant plug his obd0 harness into an obd1 dizzy, therefore wanting to reuse the one off the d15. am i right?
Old Jan 8, 2008 | 11:42 PM
424racer's Avatar
1 3 5 7 9 11 13 15 17
2 4 6 8 10 12 14 16
by looking at the back of the clip.
http://www.angelfire.com/d20/h....html
i dont know what year your car is but maybe this will help...
Old Jan 9, 2008 | 09:39 AM
2ltrtodd's Avatar
* B A N N E D *
Default Re: want to confirm before i start hacking away!!! (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">he isnt using a 97 dizzy, hes using a 97 d16 and cant plug his obd0 harness into an obd1 dizzy, therefore wanting to reuse the one off the d15. am i right? </TD></TR></TABLE>
yes. thank you.
im using a 97 d16 motor
90 d15 dizzy
pm9 ecu
and ive already finished the mpfi swap, i just need to know about the distrtibutor now. (will it work without changing pins for CYP or just leave it since its the stock computer)
Old Jan 9, 2008 | 12:45 PM
twiztid17thninja's Avatar
Which d16 do you have? if you don't know find out and then get an ecu and dizzy to match. if it is a y8 then you will need a vtec ecu othewise it will run like an hf motor with the wrong maps. You cannot do the mpfi swap with the stock ecu or the stock dizzy EVER IT WILL NOT RUN!! you should give me your car.
Old Jan 9, 2008 | 12:59 PM
2ltrtodd's Avatar
* B A N N E D *
Default Re: want to confirm before i start hacking away!!! (twiztid17thninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid17thninja &raquo;</TD></TR><TR><TD CLASS="quote">Which d16 do you have? if you don't know find out and then get an ecu and dizzy to match. if it is a y8 then you will need a vtec ecu othewise it will run like an hf motor with the wrong maps. You cannot do the mpfi swap with the stock ecu or the stock dizzy EVER IT WILL NOT RUN!! you should give me your car.</TD></TR></TABLE>
its a y7 no vtec. and first of all this in my expletivein winter beater i dont give a **** about it.
i dont have an ecu for this motor. i have the obd1 dizzy from it and the obd0 from my stock and obviously it has different plugs. instead of telling me it wont work, tell me why and which dizzy to get!
Old Jan 9, 2008 | 01:06 PM
The stock ecu does not have the capabilities to run mpfi. An MPFI dizzy has a cam angle sensor in it, which you NEED to run mpfi. An easy ECU to run is a PM6 (out of an 88-91 si/ex). If you 'don't give a **** about it,' put your old intake manifold back on, run your stock dizzy and ecu on dpfi. That's the only way to do it without buying anything.
Old Jan 9, 2008 | 01:36 PM
2ltrtodd's Avatar
* B A N N E D *
Default Re: (twiztid17thninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid17thninja &raquo;</TD></TR><TR><TD CLASS="quote">The stock ecu does not have the capabilities to run mpfi. An MPFI dizzy has a cam angle sensor in it, which you NEED to run mpfi. An easy ECU to run is a PM6 (out of an 88-91 si/ex). If you 'don't give a **** about it,' put your old intake manifold back on, run your stock dizzy and ecu on dpfi. That's the only way to do it without buying anything.</TD></TR></TABLE>
k. nah i already did all the wiring and pin switching. im not putting it back. and the stock mani sucks. ill find a ecu from someone. i got the whole thing for 100$ so w.e
blackzrd
Nov 22, 2008 10:03 AM
ScareyH22A
Honda Motorcycles
Sep 10, 2006 05:49 PM
De_tour
16
Apr 30, 2006 09:37 PM
b16awarrior
10
Sep 20, 2002 02:57 PM
SIK IN DA HED
Oct 16, 2001 09:47 AM
