high flow cat over a test pipe
Old Jan 7, 2008 | 06:59 PM
recon23's Avatar
Default high flow cat over a test pipe
I plan on purchasing a high flow cat or a test pipe for my lsvtec. I have been searching and it seems as tho a high flow cat is the way too go seeing how I am not boosted or have larger amounts of hp. So far I am leaning towards an OBX Racing High flow cat. What do you guys think?
Old Jan 7, 2008 | 07:15 PM
racebum's Avatar
Default Re: high flow cat over a test pipe (recon23)
Random tech is the default brand with our local performance croud. Fit, quality and flow are first rate. They make a direct bolt on for our integras too.
Old Jan 7, 2008 | 07:20 PM
recon23's Avatar
Default Re: high flow cat over a test pipe (idrivesideways)
im tryin not to spend more then 200 bucks.......kid in high school budget
Old Jan 7, 2008 | 07:34 PM
SuckMyDOHC's Avatar
You could find a used carsound cat for a decent price
Old Jan 7, 2008 | 09:35 PM
ls19integra95's Avatar
Default Re: (SuckMyDOHC)
in pa it wont pass inspection with a test pipe, (unless know some one )
but i am running a high flow cat on my turbo teg... really the high flow looks like a cat and the test pipe jus looks like a reg pipe almost, im sure theres a little better flow with the test pipe but dont take my word on that... i mean if your not going insane hp and stuff then just go with the high flow cat...
Modified by ls19integra95 at 10:56 PM 1/7/2008
Old Jan 7, 2008 | 09:53 PM
Schister66's Avatar
Man U FTW
If you have to pass emissions, then get the Cat...if not, then get the test pipe. Either way, you're not really going to see much in the way of power gains...
Old Jan 7, 2008 | 11:42 PM
racebum's Avatar
Default Re: (Schister66)
If you shop around a Random can be had right about 200-230
Old Jan 8, 2008 | 04:54 AM
PrinceAli132's Avatar
Default Re: (idrivesideways)
Not sure how much SMSP charges but you could get a high flow cat from him.
Ali
Old Jan 8, 2008 | 06:18 AM
Padawan's Avatar
Darth ModerVader
Default Re: (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure how much SMSP charges but you could get a high flow cat from him.</TD></TR></TABLE>
That would be my suggestion.
Better flow than Random Tech, and less expensive too.
Old Jan 8, 2008 | 10:22 AM
tomithy's Avatar
That, "OBX High Flow Racing Cat" is actually a test pipe. OBX doesn't make a catalytic converter.
Old Jan 8, 2008 | 10:37 AM
mac_24_seven's Avatar
Default Re: (tomithy)
http://www.team-integra.net/se...ID=24
That link has all the info you will need to help you make your decision. I'd go with a Car sound and be done with it, personally
DCSportEJ1Civic
26
Jul 16, 2007 12:44 PM
DpQInteg
May 13, 2006 07:40 AM
p1ccoloz
Mar 6, 2003 09:32 AM
808State
May 14, 2002 11:12 AM
00PurpleGSR
Apr 13, 2002 03:29 PM
