new shocks/springs and with a slight drop. pics.. what do you guys think?
Why don't you tell us a little bit about your suspension set-up. BTW if my monitors colors are correct, I'm seeing a electric kinda blue GSR, with OEM body kit? Is The color Stock?
tokico illuminas. with comptech springs with 1.25 inch drop all around. the ride feel so good after the installation.
here's another picture of BEFORE.
[Modified by GSblueRacing, 7:02 AM 6/30/2002]
Hmmmm, I not knowledgeable about that set up, but hopefully you did your research before going ahead with the installation. I'm considering Eibach spring for sure, but not sure if I want to go with the pro-kit(1.3) or sportline kit(1.7). I then would look into getting Koni Yellows or some other adjustable scock. But if I go ahead with the 1.7 inch drop I believe I will have to look into and do my research on coil-overs and camber kit. Not knowledgeable with camber kits or coil-overs.
kloscivicsi
Honda Civic (2006 - 2015)
32
Jul 15, 2007 08:01 AM
bradykiller
18
Nov 16, 2003 01:51 AM
