Got in an accident - What do I need to replace?!
Old Jan 7, 2008 | 04:00 PM
m1ndless's Avatar
* B A N N E D *
Default Got in an accident - What do I need to replace?!
http://www.imagedoll.com/show.php/7928_carnage.jpg
Judging from the carnage, what all do you guys think I need to replace? I am getting ready to order some parts for it, and so far I am getting a Hood, Fender, Taillight, Grill.
I havent been able to get my hood open yet, so I am not sure of the internal damage, I did notice that there was coolant all over my bumper and where my headlight was, so I assume I either busted the radiator or just the resivior.. i plan on doing a more through inspection when this storm passes in the morning.
What parts am I missing if any? I think I got anything, but I figured I should ask you guys before ordering,
I found a site that has the hood, fender, headlight, and grill for under $350 shipped, if I add a radiator and radiator support, and after the bulk discount, its only $450, do you think I need a new support or just a radiator?!
Thanks!
Modified by m1ndless at 7:09 PM 1/7/2008
Modified by m1ndless at 7:10 PM 1/7/2008
Old Jan 7, 2008 | 04:45 PM
I386's Avatar
Default Re: Got in an accident - What do I need to replace?! (m1ndless)
picture no worky
Old Jan 7, 2008 | 06:03 PM
bunburyd16y's Avatar
Default Re: Got in an accident - What do I need to replace?! (I386)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I386 &raquo;</TD></TR><TR><TD CLASS="quote">picture no worky </TD></TR></TABLE>
X2
90-93 accord jdm fog lights for sale
http://www.hondamarketplace.com/zerothread/2192143
Old Jan 7, 2008 | 06:10 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Got in an accident - What do I need to replace?! (bunburyd16y)
I guess the IMG tags don't work on this forum. I just put the direct link instead, hope that helps!
Old Jan 7, 2008 | 07:12 PM
a.wax's Avatar
I'm not sure what you can do to fix it because i have no prior experience in this. But my brother had the exact same accident. Same spot, same everything. His batter popped upwards towards the hood, and his radiotor bent backwards. The insurance just diagnosed his car TOTALEd.
Old Jan 7, 2008 | 09:57 PM
bseriescrxsi's Avatar
Default Re: Got in an accident - What do I need to replace?! (a.wax)
ok based on just looking as the outside heres it goes(if i miss anything feel free to chime in)
hood
headlights
bumper lid
radiator(possibility)
rad support assembly(depending on how low the damage is on the inside)
bumper support assembly
pass. side fender
grille
possibly some frame straightening
and i would recommend a full alignment and just check the areas around the wheels(axles,joints,tie rods,etc) checked
looks like you got lucky that the damage wasn't down further
Old Jan 10, 2008 | 11:44 AM
m1ndless's Avatar
* B A N N E D *
Default Re: Got in an accident - What do I need to replace?! (bseriescrxsi)
How much do you guys think I could get for it?
Old Jan 10, 2008 | 12:04 PM
DKYamada's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriescrxsi &raquo;</TD></TR><TR><TD CLASS="quote">ok based on just looking as the outside heres it goes(if i miss anything feel free to chime in)
hood
headlights
bumper lid
pass. side fender
grille
looks like you got lucky that the damage wasn't down further</TD></TR></TABLE>
possibly steering arm and aseebly too. my buddy did something similar last month and had to replace his rods and axles.
you wouldnt get alot for it since alot of time needs to be put into it. well whatever you decide to do goodluck
Old Jan 10, 2008 | 12:50 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Got in an accident - What do I need to replace?! (DKYamada)
You only need like $500 in parts, so I am going to ask 1800obo for it on craigslist.
Old Jan 10, 2008 | 12:52 PM
steerh67's Avatar
don't give up on the car, it sounds like you can get the parts cheap enough. If you don't know how to weld, then just find somebody to but the new radiator support in for you, or find a friend who knows how to do it and have him show you and buy him pizza and beer or something for his troubles. After that it should be pretty straight forward putting it together yourself, and it will be much cheaper than buying a new car.
Old Jan 10, 2008 | 01:10 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Got in an accident - What do I need to replace?! (steerh67)
Isnt the radiator support just bolted in? I can weld, that is not the problem, I just want a better car, I am considering a newer civic or accord.
Old Jan 10, 2008 | 02:03 PM
steerh67's Avatar
no, its welded in, and its a lot bigger than you may be thinking, it spands across the entire front end of the car, not just the top from fender to fender. If you are stuck on selling it, i think 1800 is a bit high considering the condition its in and the fact that it is a 13 year old car.
Old Jan 14, 2008 | 12:28 PM
m1ndless's Avatar
* B A N N E D *
The only damage to the rad support is where it got hit, no lower, can I just cut it off or bend it back? It is in my battery, so I cant get the old one out to put a new one, I really don't want to have to repalce the rad support if I dont have too!
I am just going to throw a hood on, a new fender, a headlight, and put a new battery, and just leave it, I dont care how ghetto it looks as long as it runs.
Old Jan 14, 2008 | 01:31 PM
-RedneckDave-'s Avatar
Working
Since you are not taking any of the advice I am gonna go ahead and lock this.
Chriskemp
May 18, 2013 06:00 PM
GraphiteMW
Feb 17, 2009 09:59 PM
HybridHatchback
29
Jul 30, 2003 11:17 AM
97itr86
Nov 5, 2002 02:07 PM
