Recently completed B18 Build Plus Graph on dyno dynamics
Old Jan 7, 2008 | 02:02 PM
cyber gook's Avatar
Default Recently completed B18 Build Plus Graph on dyno dynamics
Comments more than welcome on how I can Improve this, especially dip in power before 7000 Rpm's
Set Up; Ek Honda Civic Jordan
UKDM B18C6 engine with stock S80 LSD ITR Gearbox 3000 miles since rebuild.
-Completely Stock Type R Intake manifold and Throttle Body. AEM V2 Intake.
-Toda type 2, 4-2-1 Exhaust manifold. Custom 2.5 Inch B pipe-non silenced to Tanabee Hyper Muffler.
Head:
-3 Angle valve cut and seat
-Ported ITR head
-Jun Ti Retainers
-Ferra Broze valve guides
-Skunk 2 standard compression and size valves
-Toda Dual valve springs
-Toda B camshafts set 0-degrees
Bottom End:
-Blueprinted OEM Honda bearings throughout
-Eagle 27lb chromoly crank
-Corrillo forged rods
-Toda 81.5mm Forged pistons 12.4:1 compression, on stock head gasket
-Honda N1 crank pully
-Exedy Lightened flywheel
Tuned by Mase with Hondata S200 and 99 octain Shell V-power
Dyno Pull on Dyno Dynamics, Reads lower than Dyno jet. 4th gear pull...
Dyno print from best run of the day. 192 WHP
Engine Bay
Peace
Modified by cyber **** at 6:25 AM 1/23/2008
Old Jan 7, 2008 | 02:51 PM
TODAwhore's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (cyber ****)
Looks good..start with advancing the intake first..just a little (if you have toda cogs)..
then go with the ex.side by advancing it. Every motor is diff, but most of them like a little more advance on the intake side (B's or C's)...You should see a big jump in the numbers.
Good numbers on the D.D.
Also where is vtec set at?
Old Jan 7, 2008 | 03:01 PM
cyber gook's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (TODAwhore)
Thanks dude, for the comments. Yea a was pretty happy with the numbers for a DD.
The cams were advanced several times with the toda cogs but it seemed to like it best pulling higher power for longer at 0 degrees?
The vtec is set to come in at 5800 Rpm
What you thinkin...
Old Jan 7, 2008 | 03:13 PM
gibsanez's Avatar
AF's?
Old Jan 7, 2008 | 04:21 PM
TODAwhore's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (gibsanez)
Try bumping vtec up..6000 or higher. Did you make changes on one cam at a time?
Most of the time i have good luck when you degree them in..we had a H-C motor that just pick up 15+hp just by adv. the intake cam...With Toda's i would rather have the stronger mid range, which is what they are know for. The header could be hurting you also. i think the toda header belongs on a b16. that same set-up would make good power all the way to 10k..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">AF's?</TD></TR></TABLE>
x2
Old Jan 7, 2008 | 04:25 PM
A-'s Avatar
A-
good power RHD
Old Jan 8, 2008 | 07:36 AM
cyber gook's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (A-)
How would bumping the vtec up help...out of interest. I never thought about this before.
Cams were adjusted one at a time, intake first advance then power runs, then exhaust and power runs. No improvements in any combination we tried??? I though this was strange.
AF's were perfect...well if you think 11.8-12.1 is perfect.
I would definatly prefer a stronger mid range. Would a larger throttle body help with this set up? Like I mentioned, intake and Tb were stock.
Also I thought the Toda header was meant to be killer. If this is notthe case then what in you opinion would suit this application?
Thanks for the comments so far. At the end of the day I'm happy anyway as this is my first home made build.
Old Jan 8, 2008 | 08:15 AM
IntegraType-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyber **** &raquo;</TD></TR><TR><TD CLASS="quote">How would bumping the vtec up help...out of interest. I never thought about this before.
Thanks for the comments so far. At the end of the day I'm happy anyway as this is my first home made build.</TD></TR></TABLE>
Moving cam gears should make a difference..if it doesn't somethings wrong..
A bigger TB should help, and i'd go with a VSTack at the end of that intake..
your numbers seem low...way low.. i would have thought this motor would have been 210+whp..if u would have told me this mouth to mouth i would have easily said.. 200+whp car..192ish is ..low..really low.
Old Jan 8, 2008 | 09:54 AM
TypeR76's Avatar
nice numbers and where did you buy the toda version 2 header from?
Old Jan 8, 2008 | 10:01 AM
cyber gook's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (IntegraType-R)
^^^ Interesting comments as most have been pretty impressed with this power. I myself like you was expecting 210 ish plus with this et up...
What areas could have left me with less power than expected?
You mean attach a velocity stack to the end of the aem pipe or the bumper directing air onto the filter? Just for the dyno or for good?
Old Jan 8, 2008 | 10:02 AM
AccordSleeperZzZ's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (TypeR76)
i'd try playing with the AF's a little bit too.
+ a different intake manifold[ :cough: edelbrock performer x :cough: ] should pick up a few ponies.
nice ride, btw
Old Jan 8, 2008 | 10:06 AM
cyber gook's Avatar
A friend of mine visits Japan fairly regularly. He picked it up for me when he was at the Toda factory. Looks great and seems pretty well made but not 100% sure on the performance yet. WOuld love to try it back to back with SMSP or RMF with my set up, see if its letting me down at all. Doubt it though, Toda make good headers...
Old Jan 8, 2008 | 10:13 AM
cyber gook's Avatar
Old Jan 8, 2008 | 10:16 AM
cyber gook's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (AccordSleeperZzZ)
Play with the AF's in what way. My tuner MASE'D said they were spot on. I think that guy has the experience to know??? I actually took it to him before christmas to get a retune. We saw hardly any imporovement. Something in the set up isnt quite working...somewhere theres somethink...
Old Jan 8, 2008 | 10:17 AM
ABK's Avatar
ABK
I would not mess with a tune, since Mase tuned it. I would get rid of that v2 intake and just get a 3" intake with velocity stack. You could possibly see 200whp.
Old Jan 8, 2008 | 10:30 AM
cyber gook's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (ABK)
^^^ What do you mean by this exactly? A 3'' intake. Who makes one? Velocity stack, show me where...
Thanks in advance, you guys in the US do things a little different sometimes. Thats why I wanted mase to tune my car. I know he's a good tuner at the end of the day. I dont blame his tune at all, I just think something in my set up could be letting it down?
Old Jan 8, 2008 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyber **** &raquo;</TD></TR><TR><TD CLASS="quote">^^^ What do you mean by this exactly? A 3'' intake. Who makes one? Velocity stack, show me where...
Thanks in advance, you guys in the US do things a little different sometimes. Thats why I wanted mase to tune my car. I know he's a good tuner at the end of the day. I dont blame his tune at all, I just think something in my set up could be letting it down?</TD></TR></TABLE>
First off Search 3'' intake, i had a few threads on here about one and consider getting a blox/BPi Vstack that right there will give you some power.. and as far as i know toda headers provide good numbers..i think they compare them to the hytech's around here or something close to that nature.. If your AFR's were dead on, i'd look at the
1) ignition maps
2) Gear settings again
3) Possible New manifold??
Somethings holding your car back we got mild b18c1's with 81.25 making 215+Whp with minor bolt ons.. maybe its your dyno..but i would expect nothing less then 200whp from this setup.
Old Jan 8, 2008 | 11:27 AM
And what in the expletive, is that your throttle cable going all the way around the motor..? If so LMFAO and +1 for you sir.
Old Jan 8, 2008 | 11:35 AM
mar778c's Avatar
Community Builder
Community Influencer
The numbers look pretty good especially when you consider this was a dynamics dyno. They are notorious for reading low.
Old Jan 8, 2008 | 11:42 AM
s200 there's ur problem , should have been done on eCtune j/k
Old Jan 8, 2008 | 11:48 AM
UncleD's Avatar
Default Re: Recently completed B18 Build Plus Graph on dyno dynamics (mar778c)
I seriously cannot believe the amount of people knockin the Toda manifold. They have supported 230 whp, Jeff Evans praised it on that particular motor and how impressed he was with it. I would NOT reccommend getting rid of your header, I would direct my attention towards that "V2" intake and switch to a 3" short ram with a velocity stack.
Old Jan 8, 2008 | 11:51 AM
UncleD's Avatar
Default Re: (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">And what in the expletive, is that your throttle cable going all the way around the motor..? If so LMFAO and +1 for you sir.</TD></TR></TABLE>
The car is RHD.
Old Jan 8, 2008 | 11:58 AM
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">
The car is RHD.</TD></TR></TABLE>
I now notice that, thx for point it out, i was about to say lmfao..
Old Jan 8, 2008 | 12:04 PM
UncleD's Avatar
Not really that appealing is it? Love the way that header looks though....delicious!
Old Jan 8, 2008 | 03:52 PM
TODAwhore's Avatar
Its a DYNO DYNAMIC they read really low.. this on a dyno jet 215-220 easy
I know every motor is diff...but should of seen better mid range power by moving the gears..on some of our old Honda Challenge motor that has to run stock intake tb and bottom end, the mid range and some peak power made big changes when played with the cam gears...A/F were also a little leaner..and higher vtec settings, with a smooth cross over where you could barely hear vtec...
But again still good numbers..do a tb and some more tweaking... put it on a dyno jet since most people on here love big numbers.
