just bought a integra gs and it is overheating what can be wrong with it?
Old Jan 7, 2008 | 12:57 PM
Ricky616's Avatar
Default just bought a integra gs and it is overheating what can be wrong with it?
I have had this car for 2weeks already, it did not overheat when i got it till now. The temp goes up more than 3/4 what might be wrong? the previous owner said the car had the engine head rebuilt it only has 65k miles on the engine. Its an auto gs btw
Old Jan 7, 2008 | 01:00 PM
imsickofrice's Avatar
Default Re: just bought a integra gs and it is overheating what can be wrong with it? (Ricky616)
low coolant level? did u check howo much fluid u got? crack in the radiator? could be lots of stuff. research. and more info would h elp
Old Jan 7, 2008 | 01:01 PM
all-mtr-teg's Avatar
Check coolant level, might be low, or even old, do a flush, bleed the system of all air bubbles. Also perhaps you have bad radiator cap, bad thermostat. You can also clean the fins on the radiator, if it is covered with bugs that can have a bad effect on the radiator's cooling ability.
Old Jan 7, 2008 | 01:03 PM
Ricky616's Avatar
the coolant level is fine it didnt leak any coolant or anything, i checked it how do you bleed the cooling system? could they have rebuilt the head wrong or something which is causing it to overheat?
Modified by Ricky616 at 3:03 PM 1/7/2008
Old Jan 7, 2008 | 02:12 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (Ricky616)
get a new t-stat and radiator cap
to ghetto bleed the system, let the car cool off (which would be a good time to replace the t-stat) then take of the old cap...start the car and let it warm up, this will purge the air out
Old Jan 7, 2008 | 02:20 PM
BAYgasDC2's Avatar
my uncles car has 80k on his 94 ls timing belt snapped..was replaced..then started overheating..found out that when the belt snapped the piston hit the valve when the valves froze...so if its a rebuilt make sure they did it properly
Old Jan 7, 2008 | 02:36 PM
denraweb's Avatar
Since the head, they may have used the same head gasket which was no good and now you're driving with a blown head gasket. Have you tried to hammer it while driving? Does it smoke ANY at all? If it does, I would guess the headgasket is bad...
Other things you might want to check are:
-Coolant level (as mentioned above)
-Thermostat (replace if necessary, cheap)
-Does does your radiator fan work at all (should come on twice before car reaches normal operating temperature, I think)?
-Check for cracks on the radiator (even though you don't see coolant on the ground under the car, the radiator or other component could still be leaking)
To flush the radiator, disconnect the top and lower hoses and pull out the plug at the bottom of the radiator. It's plastic plug, usually resembling a wing nut. Twist it out and your antifreeze will pour out. Once it's all out, stick a water hose in the top of the radiator and flush it until clean water comes out. put the plug back in, and reconnect the hoses, and refill the capacity. I think it's roughly like 2 5 quart containers of antifreeze to refill.
Old Jan 7, 2008 | 03:27 PM
tomithy's Avatar
If the thermostat goes bad doesn't it fail open?
Old Jan 7, 2008 | 03:41 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (tomithy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">If the thermostat goes bad doesn't it fail open?</TD></TR></TABLE>
no not always...only the failsafe ones
Old Jan 7, 2008 | 04:00 PM
JDM92da6's Avatar
could be air pockets or thermostat,
kodylive
May 27, 2014 12:39 PM
bigsyke
Jun 7, 2008 02:13 PM
pentaq
Feb 14, 2006 05:18 AM
IntegraTionR
Sep 18, 2005 08:22 PM
D C 5
Sep 16, 2005 11:00 AM
