Lighting HID/Xenon kits, Retrofits and Associated Topics
more stupid retrofit question................. sorry im new to this
Old Jan 7, 2008 | 12:14 PM
eddie5141981's Avatar
Default more stupid retrofit question................. sorry im new to this
1. why dosent enyone retrofit there hi beams ????
2. why dosent enyone retrofit there foglights ????
3. can i use those cheap hid kits from ebay with projectors ????
4. what are the best projector to install ???
5. why do most people use 4100k hid ???? why not go 8000k or 12000k ????
i promise i wont post no more question
Old Jan 7, 2008 | 12:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: more stupid retrofit question................. sorry im new to this (eddie5141981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie5141981 &raquo;</TD></TR><TR><TD CLASS="quote">1. why dosent enyone retrofit there hi beams ????</TD></TR></TABLE>
Mainly because it's not really necessary, and because switching HIDs on and off quickly (as in flashing high beams) is not good for the system. Most "retrofits" involve projectors, which are not a good choice for high beams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie5141981 &raquo;</TD></TR><TR><TD CLASS="quote">2. why dosent enyone retrofit there foglights ????</TD></TR></TABLE>
There are very few specific HID fog lamp projectors available, so you would end up having to modify a set of low-beam HID projectors to achieve a fog pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie5141981 &raquo;</TD></TR><TR><TD CLASS="quote">3. can i use those cheap hid kits from ebay with projectors ????</TD></TR></TABLE>
Yes, but you would have to make sure that you order a kit that included standard D2S capsules.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie5141981 &raquo;</TD></TR><TR><TD CLASS="quote">4. what are the best projector to install ???</TD></TR></TABLE>
There really isn't one "best" projector, and most people take into account the size of the housing they're trying to retrofit into, as well as what they can source relatively easily and inexpensively. You aren't going to have bad results regardless of which OEM HID projectors you select, but if you really want to research them in depth, you can check out the information available over at HID Planet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie5141981 &raquo;</TD></TR><TR><TD CLASS="quote">5. why do most people use 4100k hid ???? why not go 8000k or 12000k ????</TD></TR></TABLE>
The 4100K (4300K) capsules generate the most light, with the most useful output colour. The 8000K+ kits generate less light, and the blue/purple output is not ideal.
Old Jan 8, 2008 | 01:50 PM
thanks for the info padawan
jdmtuner64
18
Jun 24, 2007 08:26 AM
mikeycivic
123
Mar 10, 2007 12:52 PM
IBriaIN
Mar 7, 2005 01:07 AM
deeksmooth
10
Jan 11, 2005 07:22 PM
GapxGuy
Jul 20, 2004 03:24 PM
