just bought a beginner welder but need 2 question answered cant find in *search*
Old Jan 6, 2008 | 11:27 PM
stockmr2's Avatar
Default just bought a beginner welder but need 2 question answered cant find in *search*
I just bought this welder: ClarkeŽ 180EN 220 Volt 180 Amp (No Gas or Gas) Mig Welder. couldnt really afford top dollar but this will do for now. but it didnt come with a plug. and im iffy at wiring together
i have a 2x 30amp breaker for my dryer so technically a 60amp and also for my ac unit
my question is: can i wire this to plug into my dryer? the welder says Operates from standard 220 VAC. but i dont have one. and is the ground and neutral the same
Max Amps: 180
Min Amps: 30
Heat Settings: Six
Max Open-Circuit Voltage: 30
+ / - Polarity control.
Circuit Breaker Req: 25 amps
Input voltage: 220 VAC
Phase: Single
Duty Cycle: 20% at 100% output
Duty Cycle: 30% at 85% output
Old Jan 6, 2008 | 11:47 PM
welfarepc's Avatar
i found this link very helpful
http://answers.google.com/answ...90944
Old Jan 6, 2008 | 11:57 PM
k24em2's Avatar
Default Re: just bought a beginner welder but need 2 question answered cant find in *search* (stockmr2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockmr2 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought this welder: ClarkeŽ 180EN 220 Volt 180 Amp (No Gas or Gas) Mig Welder. couldnt really afford top dollar but this will do for now. but it didnt come with a plug. and im iffy at wiring together
Max Amps: 180
Min Amps: 30
Heat Settings: Six
Phase: Single
Technically you have a 2x 30 amp.
Old Jan 7, 2008 | 06:13 AM
socalismylife's Avatar
I wired my welder into the A/C service pullout box. They have little circles you can break on the bottom. I just ran a cable from that and made it water tight
Old Jan 7, 2008 | 10:15 AM
stockmr2's Avatar
Default Re: (socalismylife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">
Technically you have a 2x 30 amp.</TD></TR></TABLE>
ohh... didnt know it worked like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">i found this link very helpful
http://answers.google.com/answ...90944</TD></TR></TABLE>
thats the info that im looking for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalismylife &raquo;</TD></TR><TR><TD CLASS="quote">I wired my welder into the A/C service pullout box. They have little circles you can break on the bottom. I just ran a cable from that and made it water tight</TD></TR></TABLE>
you did what im trying to do.
by the way did your welder have a neutral or ground wire and how bout ur ac box. im still unsure if netural and ground can be mixed.
thanks to all that replyed
Old Jan 7, 2008 | 06:54 PM
Default Re: (stockmr2)
the white and black are both HOT. that's why it's 220v. you have two hot leads in a 220v circuit, and no neutral wire. Netural is ALWAYS white but white is not always neutral. The bare or green wire is the grounding wire. Just match the colors at the pullout box. I wired it into the side after the pullout. that way I can make sure my circuit isn't hot after I'm done by turning off the circuit breakers first and then removing the a/c pullout.
oh and if u're using an extension cord I'd use at least 12GA. I bought a 50ft 12ga extension cord and it's worked fine.
Old Jan 7, 2008 | 09:39 PM
stockmr2's Avatar
got it done and it works. i was just to scared to wire something i wasnt to sure of.
Old Jan 23, 2008 | 03:29 PM
KENetics1's Avatar
Just wondering how you're liking this machine? I was thinking about picking up one also and just wanted some comment.
Also how much did you pick it up for and where?
Paul*DC4
Aug 16, 2007 08:41 AM
IntegraGSR-Turbo
Feb 27, 2007 12:08 AM
showtymers619
Honda Motorcycles
May 6, 2005 03:51 PM
anotheredhatch
Welding / Fabrication
21
Dec 19, 2004 09:36 AM
DsCivicEx
Dec 4, 2003 02:15 PM
