Water pump replacement guide/write for 91 accord DX F22A1
Just wondering if anybody has some pics or a writeup on how to replace the water pump on a 91 accord dx. Changing out the timing belt is a good idea too at this point I take it?
did you happen to see my write-up for the 94-97 F22B1? Not the exact same but close and gives you a good idea of whats involved.
- Timing Belt
- Timing Balancer Belt
- Power Steering Belt
- Alternator/Compressor Belt
- Water Pump
- Front Balance Shaft Retainer Kit
- Valve Cover Gasket Kit
- Timing Belt Adjuster (Tensioner)
- Timing Balancer Belt Adjuster (Tensioner)
- Timing Belt Adjuster Spring
- Timing Balancer Belt Adjuster Spring
- Camshaft Oil Seal
- Crankshaft Oil Seal
- Front Balance Shaft Oil Seal
I would also consider buying a manual, HELM Inc is the best one without a doubt. A bit pricey but more than worth it.
- Timing Belt
- Water Pump
- Camshaft Oil Seal
chandlorexia
Engine Management and Tuning
Oct 11, 2012 10:44 AM
hankd
Jan 28, 2003 05:41 AM
