Stock radio interchangeability between models?
Old Jan 6, 2008 | 07:49 PM
RiskEverything's Avatar
Default Stock radio interchangeability between models?
I have an '88 CRX and would like to put an OEM radio with CD player into it. Are there any particular radios that will "plug and play" from later model Hondas?
Old Jan 7, 2008 | 10:55 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Stock radio interchangeability between models? (RiskEverything)
You might wanna try posting in the CRX/EF forum as well. They might be more knowledgeable about the stock stereo in the car. Sorry I have no idea what other "stock" stereos will be a direct swap. Although an after market CD player is what I would recommend. There not too hard to install into a CRX at all.
Old Jan 7, 2008 | 11:20 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Stock radio interchangeability between models? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiskEverything &raquo;</TD></TR><TR><TD CLASS="quote">I have an '88 CRX and would like to put an OEM radio with CD player into it. Are there any particular radios that will "plug and play" from later model Hondas?</TD></TR></TABLE>
I believe all Honda's 88-98 use the same radio harness, 70-7901 (i think). If that is the case, you can take any OEM honda radio from 88-98 that will physically fit, and it should plugin and work.
Old Jan 7, 2008 | 11:57 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
I believe all Honda's 88-98 use the same radio harness, 70-7901 (i think). If that is the case, you can take any OEM Honda radio from 88-98 that will physically fit, and it should plug and work. </TD></TR></TABLE> Actually it's 86-97/98 and just about any single din Honda/Acura unit will work, even some later model Integras will work, all will be plug and play, however, mounting will be an issue with some units, as face plate trim can be an issue, nothing a little modding can't make work.
I would say away from 96-98 Civic HUs, they would be a bit of a pain. 94
Old Jan 7, 2008 | 07:22 PM
Default Re: Stock radio interchangeability between models? (fcm)
Thanks for the replies, everyone! I somehow ended up reading about radios on the Crutchfield website and decided to hold out for something aftermarket. I might take a picture of a stock radio, print it out and glue it to a piece of posterboard to put in front of the aftermarket radio when I'm not in the car. Call it ghetto theft-deterrent
Old Jan 8, 2008 | 05:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiskEverything &raquo;</TD></TR><TR><TD CLASS="quote">I might take a picture of a stock radio, print it out and glue it to a piece of posterboard to put in front of the aftermarket radio when I'm not in the car. Call it ghetto theft-deterrent </TD></TR></TABLE> Better yet, remove the front of the OEM radio, glue any loos ***** in place, grind off anything on the back and use it as a "dummy plate" over the aftermarket HU, [once you remove it's removable face plate] a very effective theft deterrent. 94
braass91
42
Apr 29, 2014 05:02 PM
jdmboyef9
18
Jan 29, 2012 11:09 PM
jdmboyef9
Audio / Security / Video
10
Nov 22, 2011 07:18 PM
eg686
Mar 18, 2004 08:42 PM
cxSHOE
Mar 3, 2004 09:06 AM
