JDM B16 LSD SWAP - Port Matched GSR CAMS 65mm TB ALL NEW OEM Everything
Old Jan 6, 2008 | 05:11 PM
Honda_Fanatic's Avatar
Default JDM B16 LSD SWAP - Port Matched GSR CAMS 65mm TB ALL NEW OEM Everything
FOR SALE - TW
Complete OBD1 JDM B16a Swap w/ YS1 LSD Tranny (cable)
New OEM Valve Seals and Headgasket
ARP Head Studs
ACT 6 Puck Sprung Clutch
ACT Cromoly 9lb Flywheel
All New Seals and Gaskets
New OEM Water Pump
New OEM Timing Belt and Tensioner
OBD1 Intake Mani
H22 Prelude Throttle Body
Hondata Thermal Gasket
Prelude 310cc Injectors
New Distributor Kings Distributor
New NGK Wires
Port matched TB and IM
Runs Great - Compression Tested and Leakdown Tested
Burns no oil - doesn't smoke
Can come with Axles, mounts, and linkage and even a Hondata S200 setup with a p72 ECU.
PM me with offers and questions
Old Jan 6, 2008 | 09:12 PM
Default Re: JDM B16 LSD SWAP - Port Matched GSR CAMS 65mm TB ALL NEW OEM Everything (Honda_Fanatic)
pm's replied
Old Jan 7, 2008 | 07:26 AM
Type X's Avatar
http://www.hondamarketplace.com/zerothread/1984501
2ndcoming
Jul 4, 2011 09:14 PM
FST GSR 1
May 10, 2010 06:02 PM
shadydb7
Northeast (Sales)
33
Dec 21, 2009 04:43 PM
Honda_Fanatic
Jan 15, 2008 02:07 PM
Fuzion
Sep 6, 2005 12:37 PM
