Is this setup good
Old Jan 6, 2008 | 02:10 PM
H22Accord86's Avatar
Default Is this setup good
i got a 90 civic si hatch, and i am going to build a all motor ls vtec. Here is my setup. B18b1 short block, with a gsr head. gsr tranny. tranny was going to go with exedy street clutch, and oem gsr flywheel. The gsr has stock cams, pr3 cam gears, skunk2 chrome valves, retainers, and valve springs, with skunk2 intake mani. then arp rod bolts, arp headstuds, pr3 pistons and rings. does that sound like a good setup. and ima bore the block a little pit so i kno its a circle
Old Jan 6, 2008 | 03:48 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Is this setup good (H22Accord86)
Depends what you want out of it. It may or may not suit you.
Old Jan 6, 2008 | 04:39 PM
Default Re: Is this setup good (***$nyper)
what do you meen?
Old Jan 9, 2008 | 12:38 AM
424racer's Avatar
yeah that is an okay set up just get you some stage 2 cams and some good headers and a good tune. and it will be a good set up.
and go obd1...
Old Jan 9, 2008 | 05:46 PM
Default Re: Is this setup good (424racer)
ima get cams later and thankz
ej1_civic
Dec 31, 2012 09:18 AM
takata00
Mar 30, 2012 01:25 PM
ksears
Mar 5, 2011 08:41 PM
iH8RICERZ
12
May 7, 2006 12:55 PM
methodz55
May 13, 2005 05:11 AM
