DIY: $5 AMBER Cluster
Old Jan 6, 2008 | 02:04 PM
envision's Avatar
Default DIY: $5 AMBER Cluster
Well i didn't see a DIY for this amber cluster on HT so i'd thought i'd do one. haha.
also if you look around theres alot of pictures and things of other people putting diff colors or bulbs in their clusters.
Theres also another
DIY:for changing the clock color.. posted by mac_24_seven on pg3
What you need:
Screw Driver
194 Bulbs (autozone)
10 Mins of your time.
Remove Cluster
Remove OEM BULBS
Replace OEM BULB with the new ones
Put everything back and you're done.
quick and simple DIY
Not to clean cause camera phone But its nice
Modified by envision at 6:40 PM 1/6/2008[B ][/B]
Modified by envision at 5:49 PM 1/10/2008
Old Jan 6, 2008 | 02:13 PM
PACT man's Avatar
Default Re: DIY: $5 AMBER Cluster (envision)
You didn't see a DIY for this because everyone uses LED's for hte cluster and there are like 5 DIY's for the cluster lighting in several different colors.
Heres a link to a DIY write-up just down the page:
https://honda-tech.com/zero...age=6
Old Jan 6, 2008 | 02:47 PM
clean3two3's Avatar
not bad i was thinking of doing this for my DA.take a pic with the cluster lights on in the night
Old Jan 6, 2008 | 02:53 PM
kantstandlam's Avatar
damn i would do that but i would have to change out my climate control and what not.. nice write up!
Old Jan 6, 2008 | 02:55 PM
qazaq's Avatar
i made mine light up red
and currently working on converting dashboard illumination to red as well. so far i approximated 20leds to achieve decent illumination without black spots. this is including changeover of those green lights when you press buttons
ill make a new thread on this with pics and everything, maybe even will come up with DIY for you guys
Old Jan 6, 2008 | 03:07 PM
Default Re: DIY: $5 AMBER Cluster (qazaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qazaq &raquo;</TD></TR><TR><TD CLASS="quote">i made mine light up red
ill make a new thread on this with pics and everything, maybe even will come up with DIY for you guys</TD></TR></TABLE>
this will be interesting.. cant wait
Old Jan 6, 2008 | 03:26 PM
clean3two3's Avatar
do it
Old Jan 6, 2008 | 05:12 PM
clean3two3's Avatar
question is the green part behind the cluster sensitive like if i touch it with your hands will it damage it cus im planning on changing my cluster lights and i was wondering before i touch it or anything
Old Jan 6, 2008 | 05:17 PM
Default Re: (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">question is the green part behind the cluster sensitive like if i touch it with your hands will it damage it cus im planning on changing my cluster lights and i was wondering before i touch it or anything</TD></TR></TABLE>
i dont believe so.. i did it to my gsr cluster in my eg hatch a while back, i sprayed it orange instead..
Sorry for the crappy cellphone pic
dc3Nahalf's Avatar
hmm i might run to auto zone right now
is the red bright enough to see!!
yea take a pics with the lights on
Old Jan 6, 2008 | 05:21 PM
tweek_boii's Avatar
Default Re: (dc3Nahalf)
what the hell did i do, i fallowed your instructions and bought blue bulbs from autozone same style and everything , when i put everything back together ... everyhting looks nice BUT my cluster now throws an SRS light!. i did what you did but now when i turn lights on and turn on my car the SRS light stays on! help and bump if this thread just viewed.
Old Jan 6, 2008 | 05:22 PM
Default Re: (tweek_boii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii &raquo;</TD></TR><TR><TD CLASS="quote">what the hell did i do, i fallowed your instructions and bought blue bulbs from autozone same style and everything , when i put everything back together ... everyhting looks nice BUT my cluster now throws an SRS light!. i did what you did but now when i turn lights on and turn on my car the SRS light stays on! help and bump if this thread just viewed. </TD></TR></TABLE>
did you unplug the SRS wire?
Old Jan 6, 2008 | 05:27 PM
dc3Nahalf's Avatar
Default Re: (kantstandlam)
how did the blue come out ????
what about the gas light i dnt think its ever been on?!?!?!
Old Jan 6, 2008 | 05:40 PM
tweek_boii's Avatar
nope everything that is blue lights up right?i went out right now but my bulbs dont light up, my climate control and everything else lights up and its not my dim switch here i have a pic , i just went out and now nuthing on my cluster ligths up except the stuff that lights up wen you put key in switch , oh and it doesnt show my miles no more so i know its not bulb cus when i put the normal bulbs back on nuthing i cant see how fast im going anymore i really need help people please bump . note: my climate control and parking lights light up so it isnt the 10 fuse or the dimmer switch
Old Jan 6, 2008 | 05:46 PM
tweek_boii's Avatar
ok here are the pics during the day
dont worry i took off the white things so it is the stock cluster
for now i have a LED bulb but really needs to get working BUMP if viewed
Old Jan 6, 2008 | 05:53 PM
tweek_boii's Avatar
Default Re: DIY: $5 AMBER Cluster (tweek_boii)
bump
Old Jan 6, 2008 | 06:04 PM
Mfoehrkolb's Avatar
i did mine in RED, its quite nice imo. check it out on my build thread on sig. too lazy to post pictures L*
Old Jan 6, 2008 | 06:19 PM
tweek_boii's Avatar
Default Re: (Mfoehrkolb)
looks nice! cant wait till i get my dash working!
Old Jan 6, 2008 | 06:26 PM
envision's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii &raquo;</TD></TR><TR><TD CLASS="quote">looks nice! cant wait till i get my dash working! </TD></TR></TABLE>
damn so what exactly did you do and what happened? so like your blue lights worked. but you got SRS light... then your blue lights stop working? o_O
Old Jan 6, 2008 | 06:44 PM
tweek_boii's Avatar
Default Re: (envision)
everything for my dush that works with dimmer doesnt work no more but trun signals light up ABS light up and HAND BRAKE ligths up and DOORS OPEN light up, so it must be the fuse right? wrong , because cliamte and rest light up and parking lights and headlights work so it is specifically the cluster or dash and i replaced old bulbs so i really dont know
Old Jan 6, 2008 | 06:56 PM
envision's Avatar
It could be the bulbs. Try putting the OEM bulbs back in and see if they work. idk what else could be the problem if you did everything right.
Old Jan 6, 2008 | 07:00 PM
tweek_boii's Avatar
thanks for the help but i already replaced with the oem bulbs , not the blue ones and nothing, i really need this for in the night it doesnt light up
Old Jan 6, 2008 | 07:52 PM
tweek_boii's Avatar
bump!
Old Jan 6, 2008 | 08:21 PM
tweek_boii's Avatar
bump help.....
Old Jan 6, 2008 | 09:05 PM
JDMeman's Avatar
i wna do mine red also....i love the way it looks on RSXs.....but i have a JDM ITR cluster and i dno if i should do it or not.....i wounder if it would look good or not?
