radiator fan will not turn on.
Old Jan 6, 2008 | 12:14 PM
dudeomega2000's Avatar
Default radiator fan will not turn on.
My cooling fan on the radiator on my 96 civic is not kicking on... tell me what is should do to help fix this... this car was stolen from me and i dont know what those f***ing thieves did!
Old Jan 6, 2008 | 12:16 PM
RCautoworks's Avatar
Default Re: radiator fan will not turn on. (dudeomega2000)
Either
Fan is broken
Wires are messed up
Or fan relay is broken
RIZOBIZERT's Avatar
Start by checking the fan. Run 12v to it with a ground. Don't assume it's got a ground. If the fan works start working things back. Does it have a ground? Is the fan switch plugged in? This is the one on the thermostat housing (2 pin connector).
Old Jan 6, 2008 | 12:17 PM
ke98248's Avatar
Either your plug-in connector to the fan from the car was disconnected, one of the wires running to the fan is fried/frayed, or your thermostat is history.
Trace the plug back into where it connects to the car. Disconnect it and plug a paper clip into the each of the 2 connnector spots on the clip and see if the fan goes on (car must be on full accessory mode/on).
Old Jan 6, 2008 | 12:39 PM
Hardedge's Avatar
I thought mine wasn't working until someone explained to me that it's probably just the weather. If the coolant is having no problem keeping cool by dissipating heat to the ambient air then the fan won't click on. How high is your temperature needle going?
Old Jan 6, 2008 | 12:46 PM
Default Re: (Hardedge)
not to high at all but i do live in florida and it is always hot here... just worried my engine will overheat if the fan not working
Old Jan 6, 2008 | 09:51 PM
Hardedge's Avatar
I'm in southern Arizona, so it doesn't exactly get cold here either. Just keep an eye on your gauge. There's only cause for alarm if it gets near the red or if it doesn't drop when you stop and idle for a while.
joelro28
Feb 22, 2014 12:43 PM
gotnos2
Acura TL, RL & ZDX
May 25, 2012 11:23 AM
CivicSi95
May 30, 2010 04:15 PM
loup05
Oct 22, 2006 05:20 PM
