FS - Project car (95% done)
Old Jan 6, 2008 | 10:10 AM
wespirl's Avatar
Default FS - Project car (95% done)
*** 9,500 obo ***
95 Gsr w/ 58... ORIGINAL MILES. Power locks, windows, sunroof. Power steering and A/C are not hooked up at the moment but I have all the pieces. Car cranks and runs, only thing stopping it from driving everyday is that it needs an exhaust manifold and y pipe to be matched up to the 3' exhaust or put on a turbo kit. Hondata will need to be re-tuned if running anything other than boost... but y even bother... the motor was built for boost
Exterior
* 94 - 97 Front end
* 2000 mirrors & Rear bumper
* Authentic MUGEN lip and rear spoiler (spoiler not installed yet)
* Apex-i 3' Exhaust
* 17' Konig Tantrums w/ Pirelli p-7000 tires (95% tread left)
Interior
* Momo Driver seat
* Immaculate condition pass & rear seat
* MB quarts door speaker and Tweeters
* Battery relocation kit (re-located to trunk)
* Walbro 255 hp Fuel pump
Engine bay
* Steel braided fuel lines
* Fast turbo Vacuum manifold
* Paxton Fuel pressure regulator
* Prothane motor mount inserts
* ABS removed
* Steel braided brake lines
* Tucked headlight etc.. harness
* Re-wrapped engine harness w/ resistor box wired in
Motor:
* Jdm B18B (81.5mm)
- Darton open deck sleeves
- Eagle Rods
- SRP Pistons (9.2:1)
- ARP Headstuds
- GE Headgasket
- GE Sandwhich adapter
- Honda OEM Bearings (rod and main)
- Gsr Oil Cooler
- Balanced and Blueprinted
- Tapped Oil Pan
* Jdm B16 Head
- Gsr cams
- AEM Cam Gears
- STR Fuel Rail
- Precision 780cc injectors
- Blox Intake manifold
- Hondata Intake gasket
- GE Ls/Vtec Line
- Wrinkle red painted Valve cover
* Transmission
- Hydro LS with OBX LSD ( no problems at all, sticking axles ect..)
- Competition clutch Stage 5 (6 puck sprung hub)
- Competition clutch lightweight flywheel
Management
* P28
* Hondata s200
* Boost & 3 step
* Tuned by Ed in 06. Made 358@10psi on same motor when it was in my civic
Suspension & Brakes
* KYB 5-way adjustable struts
* Ground control coilovers
* Suspension technique bushings
* Ingals camber kit
* Neuspeed Rear lower brace
* Skunk2 24mm rear sway bar
* Stock Gsr front brakes with new pads
* AEM 11.1" rear rotors
As u can see alot of time and effort has been put into the car and it's almost ready to be a complete beast on the road. I just don't have the time or energy to finish it and i'm moving home in a few months so need to start getting rid of everything I have.
*** 9,500 obo ***
Modified by wespirl at 9:15 PM 1/6/2008
Old Jan 7, 2008 | 05:58 PM
wespirl's Avatar
Default Re: FS - Project car (wespirl)
Old Jan 10, 2008 | 03:26 PM
wespirl's Avatar
Old Jan 15, 2008 | 07:56 AM
wespirl's Avatar
TTT
Old Jan 18, 2008 | 05:17 AM
wespirl's Avatar
BBBBUUUUMMMMPPPP!!!!
Old Jan 21, 2008 | 05:24 AM
BLK JDM's Avatar
Bump for a SUPER CLEAN CAR!! I've drooled over it plenty of times.
Old Jan 23, 2008 | 01:06 PM
wespirl's Avatar
Default Re: FS - Project car (BLK JDM)
TTT
Old Jan 29, 2008 | 06:06 AM
wespirl's Avatar
Old Jan 31, 2008 | 11:38 PM
wespirl's Avatar
Old Feb 6, 2008 | 05:30 AM
wespirl's Avatar
Old Feb 17, 2008 | 06:11 AM
wespirl's Avatar
TTT
Old Aug 25, 2008 | 05:38 AM
wespirl's Avatar
back from the dead
wespirl
Sep 4, 2008 06:20 PM
wespirl
Southeast (Sales)
12
Feb 17, 2008 06:04 AM
wespirl
Oct 31, 2006 07:35 PM
SmoothVTEC
Aug 25, 2006 06:01 AM
slowsupra
Jan 15, 2004 08:44 AM
