Knocking
Old Jan 6, 2008 | 09:18 AM
Teem6's Avatar
Default Knocking
I just recently replaced the head gasket and oil pump on my '94 SiR and it drove perfect for about two weeks. I passed on the highway and when I downshifted the motor stalled and wouldn't start. After getting to my garage I finally got the engine to turnover, but while running I now have a very loud knock coming from the engine compartment. Where should I start?
Old Jan 6, 2008 | 09:24 AM
wicked_b16eg's Avatar
Default Re: Knocking (Teem6)
Start with an oil change.. Look to see if you have and "glitter" like substants coming out. If you see something sprakling at you then it would be alot easier to determin what is actual wrong.
My guess is some how some thing got inside your motor when changing the HG and caused this mishap.
GL
Old Jan 6, 2008 | 10:36 AM
z6hatchboy's Avatar
Sounds to me like you didnt tension the t-belt well, when it stalled jumped timing, and you could have valves tapping away at you pistons. but i dont know if it would be running still if that happened, and its performance would deff. be sucking.
Old Jan 6, 2008 | 12:54 PM
importdreamer's Avatar
Default Re: Knocking (z6hatchboy)
sounds like rod knock if its insanely loud. If thats the case the motors trash.
Old Jan 6, 2008 | 12:57 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Knocking (importdreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdreamer &raquo;</TD></TR><TR><TD CLASS="quote">sounds like rod knock if its insanely loud. If thats the case the motors trash.</TD></TR></TABLE>not necessarily...you could rebuild it if you intended on keeping that set-up (you could even build it how you want it I.E. aftermarket) if this is even the case ....
Old Jan 6, 2008 | 01:32 PM
Default Re: Knocking (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">not necessarily...you could rebuild it if you intended on keeping that set-up (you could even build it how you want it I.E. aftermarket) if this is even the case ....</TD></TR></TABLE>
yeah if you wanna have the cylinder walls refinished, buy a new crank and rod and what ever else was ruined by the rod bearing particulates flying around in the oil . At that point the motor has been trashed. But, hey, they sell trash at flea markets, so technically its not useless.
Old Jan 8, 2008 | 08:47 AM
newbietuner_si's Avatar
pull the pan and see if it is a bearing, first good luck
tico
Jan 15, 2014 12:25 AM
EJ1_CRIS_909
Mar 16, 2012 02:41 PM
H2b-eghatch
Sep 11, 2010 06:57 AM
Honda-ls-hatch
May 4, 2010 07:13 AM
Nameless RB26
Oct 26, 2002 03:42 PM
