Doing MPFI conv. need help w/ dizzy connection.
I'm doing a DPFI to MPFI swap and I need a little help with getting the SI distributor to work. I cannot get an SI dizzy harness before the day I need this done (none availible locally it seems) by so I will have to cut the harnesses and hard wire it.
Do the wire colors on the SI dizzy match the DX harness? If they don't can someone give me that matching colors?
Also what color wires go to the two wires I had to run through the firewall for the CPS? Any and all help is of course much appreciated!
one goes to blue yellow and the other goes to blue green on the dizzy. As far as wires matching up iirc they all pretty much match up. Lmk if you need any other help
JDMkid413
Jun 11, 2009 03:16 PM
92hatchattack
11
Sep 1, 2004 05:45 PM
88rexdxa6ed
14
May 6, 2003 01:56 PM
