gsr in 88' hatch... how do you guys clear the exaust manifold.
Old Jan 5, 2008 | 07:42 PM
Dead CIVIC's Avatar
Veteran: Army
Default gsr in 88' hatch... how do you guys clear the exaust manifold.
my car has a black thing across the lower front and the exaust manifold won't clear it
*also what t braket do i need to use.??
thank you for you sare of knowlege.
Old Jan 5, 2008 | 08:00 PM
Dead CIVIC's Avatar
Veteran: Army
bump
Old Jan 5, 2008 | 08:09 PM
StorminMatt's Avatar
Default Re: gsr in 88' hatch... how do you guys clear the exaust manifold. (Dead CIVIC)
Souns like you have problems with interference with the crossmember. This CAN happen evenwith the stock manifold, depending on which mount kit you use. You have two choices: notching yor crossmember to make it fit OR an aftermarket crossmember/traction bar.
Old Jan 6, 2008 | 04:24 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: gsr in 88' hatch... how do you guys clear the exaust manifold. (StorminMatt)
oh i kind'a thought so thanks for that raspond. StorminMatt
Old Jan 6, 2008 | 04:48 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">my car has a black thing across the lower front and the exaust manifold won't clear it
thank you for you sare of knowlege. </TD></TR></TABLE>
are you talking about the front mount on the crossmember? Why don't you just cut it? Your mount kit won't use the front mount anyways for the GSR motor. The GSR header fits fine too with the stock crossmember due to its 4-2-1 design. Check my build thread, there are pics.
Old Jan 7, 2008 | 12:14 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: gsr in 88' hatch... how do you guys clear the exaust manifold. (gursh d)
ho yeah thanks for that link.
Old Jan 11, 2008 | 03:49 PM
DxTrix's Avatar
What exhaust manifodl are you running that it wont clear the cross member?
Old Jan 17, 2008 | 06:25 PM
gursh d's Avatar
Default Re: gsr in 88' hatch... how do you guys clear the exaust manifold. (DxTrix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix &raquo;</TD></TR><TR><TD CLASS="quote">What exhaust manifodl are you running that it wont clear the cross member?</TD></TR></TABLE>
4-1 style headers won't fit without 'notching' the front cross member. Either way, I would remove the front mount off the cross member to give maximum clearance. The stock GSR header fits perfectly fine with a couple inches of clearance. Here's a pic of my setup using the stock GSR header from a B18C:
Karsten
Jul 19, 2018 12:06 PM
civic-r11
Oct 9, 2009 04:06 PM
Jason703Racing
Mar 23, 2007 01:07 PM
