just installed short shifter and poly shifter bushings hows it supose to feel?
When i first installed the short shifter it was SUPER TIGHT i would have to muscle it to get into gear, i kept screwing the bolt and nut in till it wouldnt move anymore, i figured the shifter was tight because of this so i backed off and tightened the bolt and nut "BARELY" and now the shifter is perfect, is this how tight the nut and bolt on the bottom of the shifter is supose to be?
Modified by Gant at 3:08 AM 1/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadydb7 »</TD></TR><TR><TD CLASS="quote">it should be snug and not tight...</TD></TR></TABLE>
i'd rather have it tight instead of loose, in most situations in life
it should feel tight. not super tight but moveable. it feels good. u will know when its on right. I recommend changing the bushings, and bracket that gpoes around the ball part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified »</TD></TR><TR><TD CLASS="quote">it should feel tight. not super tight but moveable. it feels good. u will know when its on right.</TD></TR></TABLE>
yes you will son, yes you will
when i installed my short shifter, the linkage was spread out a abit and i pinched the bracket together a little bit, to tighten the nut to where it felt good. then i used 290 locktite, its green, and dropped some on the end of the bolt, so the the nut would not back itself off.
99fbpem1
Aug 31, 2007 08:43 PM
superbeastcrx
Sep 13, 2005 06:09 AM
whizdumb
10
Mar 18, 2003 03:55 PM
