y8 into 95 eg help
Old Jan 5, 2008 | 03:28 PM
Mak Valley's Avatar
Default y8 into 95 eg help
please don't tell me to search... i've done that already...
basically some people said to run the obd1 harness w/ obd2 clips... other say to use the y8 harness with a jumper harness or conversion clip or something... my question is: do either of these work? and if so, which one is better? also... the y8 i bought has a manual trans, and i plan on using my z6 auto trans. which brings me to my next question; could i run my z6 p28 or do i need to get an auto y8 ecu? thanks in advance for those who help.
Old Jan 5, 2008 | 03:31 PM
redb16coupe's Avatar
Default Re: y8 into 95 eg help (threewishmonkeypaw)
my .02 cents would be swap over your intake mani and dizzy and run your z6 harness and youll save alot of headaches thats if you have the z6 motor still
Old Jan 5, 2008 | 03:52 PM
Mak Valley's Avatar
yes... i still have my z6... so just to be clear you're saying i can run my z6 harness if i change over the intake manifold/ dizzy? also.. what about the ecu?
Old Jan 5, 2008 | 04:18 PM
Default Re: (threewishmonkeypaw)
you can keep your ecu it wont affect anything.. all d-series motors are the same. just the mani's and dizzy's change
Old Jan 5, 2008 | 04:20 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (redb16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb16coupe &raquo;</TD></TR><TR><TD CLASS="quote">you can keep your ecu it wont affect anything.. all d-series motors are the same. just the mani's and dizzy's change </TD></TR></TABLE>
Won't affect anything except for the engine's base timing, you mean. Oh, and that second Oxygen sensor. Oh **** - and the crank angle sensor.
Maybe it's better if you use the proper harness and ECU after all.
Old Jan 7, 2008 | 03:32 PM
Mak Valley's Avatar
so my best bet would be to get a conversion harness and use everything y8?
Old Jan 8, 2008 | 04:00 PM
Mak Valley's Avatar
is it all plug and play if i use this?
http://www.boomslang.us/obd2to1.htm
or is there more to it?
Joey Mitchell
Jul 11, 2018 02:34 PM
bigpwr
Jun 19, 2010 11:20 PM
thenick
May 2, 2004 08:27 PM
