PLEASE READ. HOW TO smoke eg amber corners found link. dont understand
Old Jan 5, 2008 | 03:25 PM
jxhxb's Avatar
Default PLEASE READ. HOW TO smoke eg amber corners found link. dont understand
okay so i just want to smoke my amber corners already chipped on a little on the edge trying to melt the glue and pry them off
it doesnt work
i found this link
https://honda-tech.com/zerothread?id=1943507
and thats exactly how i want mine but i dont understand how he did it
it just said sprayed clear and wetsanded
someone please explain????
Old Jan 5, 2008 | 04:01 PM
iam7head's Avatar
Default Re: PLEASE READ. HOW TO smoke eg amber corners found link. dont understand (jxhxb)
did you even read the whole thing?
everything= listed there
read
"paint used was tremclad gloss black
and wet sanded with 1000 grit "
Old Jan 5, 2008 | 04:30 PM
jxhxb's Avatar
YES I READ THAT
i hate jerks on here
i dont understand the process he did
u just spray paint the lights and wetsand them?
do u have to spray them lightly
how many coats
how many times do u wetsand
he said he sprayed clearcoats
what does he mean by clear coats the paint or like a clear?
Old Jan 6, 2008 | 10:06 PM
xunsungheroesx's Avatar
Default Re: (jxhxb)
*If the paint he used is a spray paint then basically yes.
do u have to spray them lightly, how many coats
*This depends on how dark you want your lights to turn out. If you want to find out how many coats the person used, pm them and ask. Otherwise, spray yours until you like how it looks.
*Wet sand after the paint dries to smooth out the surface. That's what gives it the smooth, shiny finish.
he said he sprayed clearcoats; what does he mean by clear coats the paint or like a clear?
*It's a transparent, colorless paint. You can find them in spray cans too. Usually the color says crystal clear or clear or something like that. The clear coat is an overcoat, put on over the dried paint to protect it. The spray cans probably have directions on them. Once you actually try this out you will see that it's not as hard or confusing as you think.
Old May 30, 2008 | 09:34 AM
acmoc's Avatar
Default Re: (xunsungheroesx)
you can go to a local craft store and just ask for stained glass spray paint, much easier. Or get this http://cgi.ebay.com/ebaymotors...ZWDVW
vans smoke stuff, comes in many different colors
juice91si
91
Oct 28, 2010 07:01 PM
alupso
Sep 5, 2006 08:56 AM
nek0
Jul 19, 2003 06:27 AM
93dx--hatch
Apr 16, 2003 09:47 AM
Ef Whore
Nov 29, 2002 08:03 AM
