Can someone make me custom -3 brake lines??
Old Jan 5, 2008 | 03:02 PM
Hondatuner88's Avatar
Default Can someone make me custom -3 brake lines??
Lookin for someone to make me some brake lines, I recently relocated my prop valve inside my car and now neeed long lines, Please let me know if anyone can do this for me, Thanks!!
Old Jan 5, 2008 | 04:39 PM
blindstudios's Avatar
Default Re: Can someone make me custom -3 brake lines?? (Hondatuner88)
Check out http://www.speedwaymotors.com
They have -3 and -4 braided and kevlar brake lines for damn cheap.
It's good stuff, used some of their kevlar lines on a custom disc swap.
Also have stainless braided with 90 degree fittings
Old Jan 5, 2008 | 05:50 PM
Default Re: Can someone make me custom -3 brake lines?? (blindstudios)
They would work but I need them longer than 48 inches, i have to go to the prop valve under the dash to the rear disc brakes. Anyone know any more info? Thanks as always!
Old Jan 5, 2008 | 08:17 PM
jonsayre's Avatar
I can get them made but I would need an exact length and the exact fittings that would need to be used. There is an industrial hose supply shop near me that does custom work @ great prices. They have nearly any fitting imaginable for brake lines.
Old Jan 8, 2008 | 02:05 PM
a1320addict's Avatar
Default Re: Can someone make me custom -3 brake lines?? (jonsayre)
PM me the following:
Specific Length of each line
Type of Hose Ends you want, straight, 45º, or 90º
Already know you need -3 AN
These are crimped, not Earl's DIY
Old Jan 8, 2008 | 02:41 PM
T4 Neon's Avatar
Default Re: Can someone make me custom -3 brake lines?? (a1320addict)
... or contact http://www.hosenow.com (Detroit Flexible Metal) - they also can make you anything you want to your specifications. I use them because they're local to me, always can find / make what I need, and the pricing is reasonable.
Old Jan 9, 2008 | 05:41 AM
EdsGTI's Avatar
Default Re: Can someone make me custom -3 brake lines?? (DaveF)
moreland hose in NY could do this for you too, im local to them and could help you out if you needed
Old Jan 9, 2008 | 06:14 AM
DaveF's Avatar
Default Re: Can someone make me custom -3 brake lines?? (EdsGTI)
there is a place like 5 minutes from here, and probably 30minutes from the OP. they can do it while you wait.
Old Jan 9, 2008 | 07:09 AM
DaveF's Avatar
Default Re: Can someone make me custom -3 brake lines?? (rota92)
the place near us does DOT approved stuff (stainless braided with clear rubber coating on the outside) all profesionally crimped, no diy put it together yourself type stuff
Old Jan 9, 2008 | 07:13 AM
DaveF's Avatar
yes, you can tell them what its for, they do custom brake lines and such for cars /motorcycles/ whatever. its mainly an industrial hose/hydraulic type of place. they have a bunch of fittings and what not there too.
i dont think they would let you leave the place with a "non dot" approved hose for a brake line. maybe for a racecar, but i guess that relates back to how much you tell them
Old Jan 9, 2008 | 04:26 PM
manifoldmiketyson's Avatar
somthing wrong with diy?
not sure about he earls fittings, but the aeroquip stuff works great.
Old Jan 9, 2008 | 04:36 PM
triple_s1x's Avatar
Default Re: Can someone make me custom -3 brake lines?? (manifoldmiketyson)
Something like this might work out...
http://www.hrpworld.com/index....oduct
Old Jan 9, 2008 | 10:44 PM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manifoldmiketyson &raquo;</TD></TR><TR><TD CLASS="quote">somthing wrong with diy?
not sure about he earls fittings, but the aeroquip stuff works great.</TD></TR></TABLE>
most of the DIY stainless hoses are not teflon lined and that's what you need for high pressure.
Old Jan 11, 2008 | 06:38 PM
jspek.com member's Avatar
make sure if you are mating up to any stock fitting to check what flare you have.
some Hondas have a metric BUBBLE flare while a few others(gsr mc port) have double flare.
on dc5's all fittings are metric BUBBLE flare tho.
you can go to a place like napa auto parts and buy pre flared lines with fittings. use the fitting end and flare for your prop. then use a -3 an going to a bulkhead to mate up the rear lines.
Corksil
Suspension & Brakes
Jan 1, 2012 10:53 AM
HamiltonRex
Dec 19, 2010 08:10 AM
nickzed20
10
Feb 26, 2005 12:43 PM
pumafeet10
Aug 19, 2004 03:44 PM
HondaGSR
Honda Motorcycles
Feb 3, 2003 04:09 PM
