Normal for new laser cut flanges to be warped?
Old Jan 5, 2008 | 11:17 AM
socalismylife's Avatar
Default Normal for new laser cut flanges to be warped?
I just received a laser cut f20c flange from precision power parts. The problem is that it is warped about 1/16" in the middle. The heat affected range around where the laser cut is very small, so it seems strange why a 3/8" flange would warp that much. What do you guys think?
Old Jan 5, 2008 | 11:51 AM
k24em2's Avatar
Default Re: Normal for new laser cut flanges to be warped? (socalismylife)
Most plate stock isn't perfectly flat.
Old Jan 5, 2008 | 12:12 PM
ebydrc's Avatar
Banned
thats normal for laer cut, and being 3/8 plate isnt always flat like stated before.
Old Jan 5, 2008 | 12:52 PM
Default Re: (ebydrc)
okay i see. well when I weld it I think I'll just weld it on the convex side so it'll warp back closer to flat. I also see how some people cut the flange along the bolt holes so the flange is separated into 3 sections. That would help the flange seal better once i'm done welding right?
Old Jan 5, 2008 | 01:13 PM
RCautoworks's Avatar
1/2 yes, 3/8 not so much. We bought some laser cut ones from weirtech ( 3/8 ) and they were flat.
Old Jan 5, 2008 | 02:55 PM
manifoldmiketyson's Avatar
Default Re: (RCautoworks)
depends on the sheet that they are cutting them from, but they are usually warped, especailly if they are stainless.
i would straighten that before you weld it.
if you have access to a shop press, use that to straighten it. works like a charm.
bmc surfaces all of their flanges
Old Jan 5, 2008 | 02:59 PM
Default Re: (manifoldmiketyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manifoldmiketyson &raquo;</TD></TR><TR><TD CLASS="quote">
bmc surfaces all of their flanges </TD></TR></TABLE>
And takes months to send you them.
Old Jan 5, 2008 | 05:47 PM
No it's mild steel. I don't have a shop press. anything else I can try?
Old Jan 5, 2008 | 06:02 PM
weiRtech's Avatar
OG Fabricator
none of my flanges go out if they are warped.
i'd recommend making a thick plate to bolt it to when you weld the runners onto it... it should flatten out a bit if you let it cool on the fixture.
i also recommend re tightening head studs on manifolds after you heat cycle them the first couple times. that is to say, re tighten the studs while it is still hot so it will cool flat. i've done this in the past with my own personal manifolds and 1/2" flanges that were warped more than 1/16" and it came off glass flat afterward.
Old Jan 5, 2008 | 07:17 PM
mrbsponge's Avatar
Default Re: (weiRtech)
A lot of the problems with the metal itself is thats its not flat to begin with. sad part is on 3/8 plate ASTM tolerance is like about 1/4 inch every 24 inches
fortunatley we use 1/4ASTM tolerances and will not send out material like that
our steel is heat treated-&gt;quenched--&gt;tempere--&gt;hot levelled @2400+tons with backup rolls--&gt;cooled--&gt;sheared--&gt;shot blasted--&gt;stenciled, labeled, tagged, inspected and shipped
3/8th heat treated plated 240inches by 96 inches wide=12-15,000.00
but its flat, wont warp, and is in an "armor" classification
Old Jan 5, 2008 | 07:23 PM
hey I sent you a reply but you never got back to me. I was going to order from you at first.
Old Jan 7, 2008 | 07:02 AM
legendboy's Avatar
Default Re: (socalismylife)
I always get my el'cheapo hot rolled plasma cut flanges made 5/8" so there is room for me to machine after welding. The ones i get done locally are almost always warped.
Old Jan 7, 2008 | 10:09 AM
Running925's Avatar
Default Re: (legendboy)
bolt it to the head or a flat surface that will hold it flat, then build your manifold. When your done all the runners will actually hold it in place. When you dismount the flange from the head then it will hold, then when u run the manifold a few times, the heat will conform it & the stress will be releaved
Old Jan 7, 2008 | 10:29 AM
weiRtech's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalismylife &raquo;</TD></TR><TR><TD CLASS="quote">hey I sent you a reply but you never got back to me. I was going to order from you at first.</TD></TR></TABLE>
my apologies. best bet is to email or call if you don't get a pm response within 12 hours.
Old Jan 7, 2008 | 03:46 PM
CSaddict's Avatar
Every flange I have received from Weir has been perfectly flat. They weld nicely too.
Old Jan 7, 2008 | 03:47 PM
I did email. no response. oh well. i guess i'll just work with what i've got now.
Old Jan 7, 2008 | 05:41 PM
vtec_lude's Avatar
He'll get back to you. I love the flanges I get from weir. Fantastic price and fast delivery.
Old Jan 7, 2008 | 08:42 PM
zman's Avatar
Default Re: (vtec_lude)
weiRtech is the man!!!
Definately the one i trust for this kind of stuff (fabrication).
Old Jan 8, 2008 | 06:41 PM
JDMCRX's Avatar
Default Re: (zman)
Yeah i noticed i got a couple of pieces of 3/16 to 3/8" sheets of steel and was warpped also
Old Jan 8, 2008 | 07:21 PM
2kjettaguy's Avatar
Default Re: (JDMCRX)
Normal with laser cutting unfortunately. Machining them would be better, but costs 2x more. There's pros and cons to each type of cutting for 2D flanges.
Old Jan 9, 2008 | 07:45 AM
89crxhf's Avatar
Default Re: (2kjettaguy)
warping also has to do with the type of steel used. Most of the milled out flanges are made from cold rolled steel which is a far superior steel when compared to hot rolled steel. You cant get cold rolled steel in plate form ( 48"x96" plate) it only comes in bar stock. I have cut both types of steel on my waterjet , the same part from both types of steel and the hot rolled came out warped where as the cold roll came out perfectly flat.
Welding / Fabrication
17
May 7, 2012 03:58 PM
MidShipCivic
12
Mar 5, 2010 05:31 AM
JCushing
May 21, 2006 11:34 AM
hotrex
34
Jun 4, 2005 09:02 PM
v0lcom27
Apr 27, 2005 08:00 PM
