91 Accord overheating when Idle
Old Jan 5, 2008 | 08:29 AM
sytanek's Avatar
Default 91 Accord overheating when Idle
Basically car overheats because the fans are not coming on unless the ac is on or the car is off. replaced the fan switch at the therm housing. Still happens. When I short the plug for the switch with the key on, the fans come on. Any ideas? Bad switch still?
Thanks!
Old Jan 5, 2008 | 09:33 AM
sytanek's Avatar
small update
i let the car coll the whole way down, started it up again, waited for it to heat up at about 80% to Hot, the fans came on for about 30 seconds, then went back off, the temp gauge still shows about 75% to hot.
Edit: It sees this fan switch just runs hotter than the last one. Thanks!
Modified by sytanek at 10:47 AM 1/5/2008
gtg162y
Jan 15, 2013 03:35 PM
daves91honda
Jun 4, 2009 02:53 AM
honda_hb
May 24, 2004 08:59 PM
jwitey
Apr 16, 2004 12:01 PM
