B20 into a DA integra?
Old Jan 5, 2008 | 02:10 AM
2004CIVICSI's Avatar
Default B20 into a DA integra?
Is a b20 anymore complicated than other b series swaps into a DA?
Old Jan 5, 2008 | 06:05 AM
gibsanez's Avatar
Default Re: B20 into a DA integra? (2004CIVICSI)
It's still a B series....
Old Jan 5, 2008 | 06:47 AM
jhammond_82's Avatar
Reject Papi
Default Re: B20 into a DA integra? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">It's still a B series....</TD></TR></TABLE> x2
Old Jan 5, 2008 | 06:51 AM
integrawow's Avatar
I think that the only difference is that the B20 has its coolant temp sensor located in a different location or something like that which requires extending the wires. I'm not completely sure, so don't take this to heart. I know that there is something that has to be slightly modified, but it's nothing serious at all. Don't take my word for it completely. I think you'll be okay with this swap.
Good luck with the swap though, and i'm sorry that I couldn't be of more help to you.
Old Jan 5, 2008 | 11:32 AM
daDreams's Avatar
this swap is pretty easy. i've done one. you just have to worry about the coolant temp sensor, use an obd-0 dizzy and you should be fine everything else should match up!! good luck
Old Jan 5, 2008 | 05:56 PM
PACT man's Avatar
Default Re: B20 into a DA integra? (daDreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daDreams &raquo;</TD></TR><TR><TD CLASS="quote">this swap is pretty easy. i've done one. you just have to worry about the coolant temp sensor, use an obd-0 dizzy and you should be fine everything else should match up!! good luck </TD></TR></TABLE>
Actually depends on what year the DA is whether you use an OBD-0 or OBD-1 distributor and such. My 92 was OBD-1 so I kept everything OBD-1. Swapping a B20 into a DA is just like putting in any other LS motor, its the same thing just with a bigger bore, it is the easiest swap there is to do to a DA.
Josh McLean
Honda Civic (2001 - 2005)
Mar 23, 2017 08:25 PM
sekoo_88
Feb 26, 2014 01:23 PM
JDMDALOUIE
Jul 23, 2011 12:03 AM
Nameless RB26
14
Jul 29, 2009 06:10 PM
4drRacer
Sep 3, 2002 06:07 PM
