HELP! itr sway bar install
sup guys, so i got a itr22 mm rear sway bar from a friend. he said i could use the existing hardware and d brackets from my old set up....but it looks like i cant...what do i need to bolt the swaybar down to the chassis?? any specific bracket a certain company might make?? and would the stock ls endlinks off the ls sway bar work for the itr 22 mm one?? please help me out!! thanks
Team-Integra.net has a writeup on installing the ITR sway. Your stock endlinks will work, but it would be a good idea to replace the bushings in them. You'll need a set of ITR D-brackets, I just ordered a pair from my local acura dealership this week for 7.95 each.
thanks for the reply!
ummm so i would need the d brackets?? cause i have the rubber pieces already.i just need the metal brackets to get it onto the chassis...is it a good idea to get a ASR reinforcement bar?? ive heard running a itr sway can rip out ur subframe??
its for a DC4...
its for a DC4...
youll need the d-brackets + rubber bushings for the d-brackets specific for itr.
and i believe you can use the stock endlinks.
as for an ASR brace, i dont think you need one. dc's have much stronger chasis then ek's.
but it wouldn't hurt to get one. better safe than sorry.
Yes you use your existing hardware and i think almost everyone will recommend a reinforcement brace. Companies like ASR, beaks, and comptech offer what you're looking for.
well i tried out the bar last night and the stock ls hardware wont work besides the endlinks...
so the d brackets are pretty cheap?? i already have the bushings....
yeah im thinkin bout pickin up a reinforcement bar soon
so i got the D-brackets specifically for the itr sway, and it still didnt work out with mine.....any reason why not?!?!
dgdarien
10
Mar 30, 2003 01:09 PM
