oil thickeners???
Old Jan 5, 2008 | 01:03 AM
ls_bitik's Avatar
Default oil thickeners???
is it bad to use those lucas oil stabilizers on vtec engines?? i was just wondering because dont do those motors need thinner oils? im currently using 10w30 oil in my lsv. whats the best oil should i use? 5w30? thanks for the info!!!
Old Jan 5, 2008 | 05:52 AM
nelsond's Avatar
Default Re: oil thickeners??? (ls_bitik)
dont use lucas cause it puts a strain on the oil pump when its cold cause its so thick stick with the 5w-30 high rpm oil quaker state q its pretty good and if you want more oil pressure just shim the oil pump
Old Jan 5, 2008 | 09:59 AM
AllMotorRandy's Avatar
Default Re: oil thickeners??? (nelsond)
care to explain how to go about shimming the oil pump for more oil pressure? seems interesting.....
Old Jan 5, 2008 | 10:14 AM
DonF's Avatar
Default Re: oil thickeners??? (AllMotorRandy)
You shim the relief valve to open at at higher PSI.
Old Jan 5, 2008 | 10:34 AM
SMSP's Avatar
Default Re: oil thickeners??? (DonF)
Old Jan 5, 2008 | 10:49 AM
ls_bitik's Avatar
Default Re: oil thickeners??? (SMSP)
so just use 5w30? its a preety new enine with 2000 mile on it
Old Jan 5, 2008 | 02:00 PM
Team Evol Tyrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_bitik &raquo;</TD></TR><TR><TD CLASS="quote">is it bad to use those lucas oil stabilizers on vtec engines?? i was just wondering because dont do those motors need thinner oils? im currently using 10w30 oil in my lsv. whats the best oil should i use? 5w30? thanks for the info!!!</TD></TR></TABLE>
i use the stabilizer on my engine. I only pour in half the bottle though cars been running great same oil pump and raced on a regular. Who knows though might be only a matter of time.
Old Jan 5, 2008 | 02:33 PM
rebo0t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">You shim the relief valve to open at at higher PSI. </TD></TR></TABLE>
i know endyn does this in house and sells it. what would be a proper way for DIY? i've seen it done on another cars but not personally on a honda yet.
Old Jan 5, 2008 | 04:06 PM
matt k's Avatar
so you mean your not supposed to cut the spring
Old Jan 5, 2008 | 04:07 PM
Fkned's Avatar
Default Re: oil thickeners??? (rebo0t)
In a performance application most people are trying to shed oil from their moving parts for reasons like weight and windage.
Old Jan 5, 2008 | 11:30 PM
95dcsleeper's Avatar
Default Re: oil thickeners??? (Fkned)
shimming? how and what?
Old Jan 6, 2008 | 01:01 PM
DonF's Avatar
Default Re: oil thickeners??? (bob menuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob menuts &raquo;</TD></TR><TR><TD CLASS="quote">so you mean your not supposed to cut the spring </TD></TR></TABLE> Depends if you are using Endyne clearances, then yes you can cut the spring. I thought we were talking High-performance/ race stuff, not stock LS stuff.
promotor
Jul 8, 2011 03:43 PM
92civichatchsir
32
Aug 28, 2005 03:10 PM
turboman
Jul 19, 2005 08:28 PM
b18b98
Jul 29, 2002 07:56 AM
