DA bumper gaps won't go away!
Old Jan 4, 2008 | 11:30 PM
H22CD7's Avatar
Default DA bumper gaps won't go away!
So I'm having a hard time putting my front bumper back on my 91' Integra after installing my JDM one pieces. It fit perfectly fine with no gaps at all before I took the bumper off and now no matter what I do now I have about a 1/4" to 1/2" gap on both sides by the fenders. It also will not seal with the bottom of my headlights like it used too. So what's the deal? How come I can't get it back on properly after taking it off? If I would of known taking it off would off gave me a gap like that I would of stuck with my USDM lights.
I also have a gap problem on my rear bumper too. The rear has always been like that since I owned the car though. I tried loosening all the bolts and pulling up on the bumper and tightening it again but it didnt do anything. There is around a constant 1/2" gap all the way around the rear bumper that no matter what I do won't go away. It looks really ugly when directly behind me because you can see all the white plastic clips through the gap.
So why won't my bumpers go back on right? I'm the third owner of the car but it has been in my family since new and it has never been wrecked so I know for a fact that isn't the problem. So what's the deal? Is there a special way I should be putting it back on? Are there any tricks to it or anything?
Old Jan 5, 2008 | 01:54 AM
northemt88's Avatar
Default Re: DA bumper gaps won't go away! (H22CD7)
i would just say take it all back off including the bumper bar and everything and reinstall it
Old Jan 5, 2008 | 03:15 AM
H22CD7's Avatar
I have, multiple times. No matter what I do I can't seem to get rid of the gap.
Old Jan 5, 2008 | 05:23 AM
m735is's Avatar
Default Re: (H22CD7)
If it fit before you did the headlights, then the problem must be the headlights. Closely compare the mounting points on the original assmblies with the replacements. From here, it sounds like the part of the bumper slides into the base of the headlights isn't going in far enough.
There isn't a differnce in the headlight assemblies like there is in the bumpers is there? Like 90-91 and 92-93.
Can't help for the rear, if it's all stock and never been hit, it should fit. Are all of the clips unbroken?
Old Jan 5, 2008 | 10:38 AM
clean3two3's Avatar
not trying to be a dick or anything but umm i dont think for putting on the lights you need to take the bumper off from what i know of you just take off the old lights swap in connect and plug in and bolt down thats how i got mine in.but maybe you can put something to help elevate it back to the original position.oh and put a pic i want to see how big the gap is
Old Jan 5, 2008 | 01:48 PM
northemt88's Avatar
if nothing else you can diy and use screws from the inside to snug it up or maybe silicone, a pic would be awsome.
Old Jan 5, 2008 | 02:38 PM
HONDRETTI's Avatar
Default Re: (northemt88)
you may have missed replacing a few bolts...find a diagram or retrace each step you took taking it off, there should be no difference in fitment considering your new headlights...
Old Jan 5, 2008 | 04:09 PM
clean3two3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northemt88 &raquo;</TD></TR><TR><TD CLASS="quote">if nothing else you can diy and use screws from the inside to snug it up or maybe silicone, a pic would be awsome.</TD></TR></TABLE>
x2
Old Jan 5, 2008 | 08:06 PM
rockofcali's Avatar
Default Re: (clean3two3)
losen the 4 bolts behind the blinker lights and use sum muscle to push up the bumper assymbly and tighten the bolts bak up
Old Jan 5, 2008 | 08:19 PM
GsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">not trying to be a dick or anything but umm i dont think for putting on the lights you need to take the bumper off from what i know of you just take off the old lights swap in connect and plug in and bolt down thats how i got mine in.but maybe you can put something to help elevate it back to the original position.oh and put a pic i want to see how big the gap is </TD></TR></TABLE>
You have to remove the bumper to take the lights out. Someone must have already removed your lights before if you didnt have to. There are 3 bolts on top of the light then there are 2 others underneath and you need to remove the bumper cover to get to the bottom bolts.
Old Jan 6, 2008 | 12:02 PM
clean3two3's Avatar
i guess they did then.but after installation you dont need to put the 2 bottom bolts on just the top 3
Old Jan 7, 2008 | 10:30 AM
m735is's Avatar
Maybe the foam inside the bumper shifted somehow and is holding it from going back correctly.
Old Jan 7, 2008 | 10:52 AM
GsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">i guess they did then.but after installation you dont need to put the 2 bottom bolts on just the top 3 </TD></TR></TABLE>
I still would, especially if you have JDM one pieces. Just because people would be likely to steal those and it would be easy as hell to steal with just the top bolts holding them in place. But if you have the bottom bolts on a thief would need to take your bumper off to get them out, not likely.
Plus the top 3 mounting tabs on one pieces are plastic and the bottom 2 are metal, I don't like the idea of them only being attached to the car by some flimsy damn near 20 year old plastic. I could see a tab breaking just by hitting a good size pothole or something.
Old Jan 7, 2008 | 11:48 AM
super jdm yo's Avatar
Default Re: (GsDAteg)
yeah i would also suggest to bolt up the bottom as well. if you want to use both bolts down there, you'll have to exchange the brackets off you the usdm with the jdm to fit right. the splash gauges on the bottom of the bumper could and would get in the way. that's what was giving me the problems with my gap. because it actually goes on the inside of the bumper but if you leave it on the outside it'll push the bumper out a little.hope this helps and goodluck
Old Jan 7, 2008 | 02:10 PM
lsda9's Avatar
I know that in the front, under the headlights there are these rubber strips that kind of "tounge and groove" fit on the top side of the bumper so the headlights rest on the rubber and not the bumper. When i repainted by first DA i removed the bumper to paint it and when i reassembled the front end i noticed the same kind of gaps and then noticed the rubber was still lying around. If you dont know the rubber pieces i am talking about then your headlights were probably already removed and those pieces were forgotten along with mine. and with the rear you might just try to remove the bumper cover and wrench on the support (trying to pull it up). Youve probably already done this but look for the bolts that hold the rear support on and see if the holes for the bolts are slotted (giving you adjustment up and down). Hope this helps
Old Jan 7, 2008 | 04:28 PM
oldsk00Lfunk's Avatar
Default Re: DA bumper gaps won't go away! (lsda9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsda9 &raquo;</TD></TR><TR><TD CLASS="quote">I know that in the front, under the headlights there are these rubber strips that kind of "tounge and groove" fit on the top side of the bumper so the headlights rest on the rubber and not the bumper. When i repainted by first DA i removed the bumper to paint it and when i reassembled the front end i noticed the same kind of gaps and then noticed the rubber was still lying around. If you dont know the rubber pieces i am talking about then your headlights were probably already removed and those pieces were forgotten along with mine. and with the rear you might just try to remove the bumper cover and wrench on the support (trying to pull it up). Youve probably already done this but look for the bolts that hold the rear support on and see if the holes for the bolts are slotted (giving you adjustment up and down). Hope this helps</TD></TR></TABLE> I agree with lsda9, maybe it is the rubber pieces your missing on your front bumber because on my 92 one side of my headlights has it and the other side doesn't so you can really tell the diff. there is a big gap between the headlight and the bumber. With the rear bumber I'm having the same problem with one side being gapped.
Old Jan 7, 2008 | 04:32 PM
Brice.Hayden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">
Plus the top 3 mounting tabs on one pieces are plastic and the bottom 2 are metal, I don't like the idea of them only being attached to the car by some flimsy damn near 20 year old plastic. I could see a tab breaking just by hitting a good size pothole or something.</TD></TR></TABLE>
I've had the top3 only holding mine on for almost 5 years.
there goes that theory. i guess you should stop asking Miss Clio.
Old Jan 10, 2008 | 02:12 PM
GsDAteg's Avatar
Wow, good for you. Would you like a cookie? I have seen countless one pieces for sale with missing/broken tabs due to lazy asses like you. Just because it hasn't happened to you yet doesn't mean it can't.
And what's the point of only bolting the tops down anyway? What are you benefiting by not bolting the bottoms? You do realize any thief could rip those lights out of your car in about 60 seconds, right?
wen61dan
Paint and Body
Jun 13, 2014 09:39 AM
ten2doyle102
Paint and Body
Aug 24, 2008 03:20 AM
hondafreak2007
Honda Civic (2006 - 2015)
Jul 8, 2007 06:57 PM
nonsense
May 28, 2004 08:02 AM
Zulu888
Sep 22, 2002 06:46 AM
